"Boston Comes To Brooklyn"
Goto page 1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Fri Oct 23, 2020 12:21 pm    Post subject: "Boston Comes To Brooklyn" Reply with quote
In the July/August 1992 issue of the old "ELECTRICLINES" magazine, there is an excellent photo article on the vintage streetcar/rapid transit equipment that was then being used in the then-filming Spike Lee film, "MALCOLM X".
For sequences set in Boston, a train of Museum BMT "D"-Types were lettered for the "BOSTON ELEVATED RAILWAY", and were furnished with destination sign readings (from Boston) typical of that era.
The units were not running under their own power, and were hauled by a small SOUTH BROOKLYN RY. diesel.
What was a bit odd (at least to me), was that a train of the "Standards" were not used instead; the Standards, after all, were inspired by the 1912-era Cambridge-Dorchester (today's "Red Line") rapid transit cars.
Too, nothing like the "D" types ever operated on Boston's rapid transit network (perhaps the Standards were unavailable to the filmmakers at that time)
Also, recall that, in the early 1990's, it was impossible to film "el" sequences, as the "Main Line El" came down in the 1970's (the former BMT Myrtle Avenue elevated subway line was used in the film)
Also in the same film, a Birney from Seashore was brought down to Brooklyn, and a 1000-foot long stretch of overhead was erected over old rails near Bush Terminal.
This was to recreate the scene in Lansing, Michigan, where Malcolm's father was chased to his death in front of a Lansing streetcar; this Birney (The B&QT operated Birneys into the 1930's) was lettered "MICHIGAN ELECTRIC RAILWAY.
After the filming, this car was sent back to Seashore (a portable generator/rectifier powered the car while filming took place), and the Museum "D"-types had the BERy lettering and Boston destination signs removed........
PostPosted: Fri Oct 23, 2020 12:34 pm    Post subject: Reply with quote
Here's a 1970's-era photo showing two old Boston "Red Line" cars being used in work service; as you can see, there is some resemblence to the BRT/BMT "Standards".......
https://www.newdavesrailpix.com/boston/htm/usr_h_bos_redline_workcars_jt_bos127.htm
(courtesy: davesrailpix)
PostPosted: Fri Oct 23, 2020 12:41 pm    Post subject: Reply with quote
Again, you can see some of the BMT "Standard" in this ex-Boston "Cambridge" car at the Seashore Trolley Museum.
Note the doors that slid on tracks mounted outside the cars; some of the BMT "C"-type elevated cars used a similar arrangement.......
https://www.newdavesrailpix.com/boston/htm/usr_h_bos_seashore_0719_seashore_jt_bos399.htm
PostPosted: Fri Oct 23, 2020 12:52 pm    Post subject: Reply with quote
Birneys seemed an odd choice for use on "big city" systems, including Brooklyn.
The Brooklyn cars mostly worked the lightly-traveled lines, including various shuttle.
One B&QT Birney survived at the 9th Avenue depot until 1956 (in work service), when the last streetcars in Brooklyn pulled down their poles for the last time.....
https://www.newdavesrailpix.com/nyc/htm/bqt657.htm
PostPosted: Fri Oct 23, 2020 12:56 pm    Post subject: Reply with quote
Compare this view of a BMT "Standard" with the views of the original Boston "Cambridge" cars.......
https://www.nycsubway.org/perl/show?26222
Last edited by NEW YORK OMNIBUS 2629 on Fri Oct 23, 2020 12:58 pm; edited 1 time in total
PostPosted: Fri Oct 23, 2020 12:58 pm    Post subject: Reply with quote
Here's another view......
https://www.nycsubway.org/perl/show?87169
PostPosted: Fri Oct 23, 2020 1:07 pm    Post subject: Reply with quote
The old Boston "Main Line El" cars in lasted in revenue service until the early 1960's; as you can see here, these elderly cars would not have looked at all out of place in New York (these cars look like IRT "Lo-V's" on steroids!!!) Shocked
Also, note the different roof styles......
https://www.newdavesrailpix.com/boston/htm/usr_h_bos_orangeline_0973_jt_bos281.htm
(courtesy: daverailpix)
PostPosted: Fri Oct 23, 2020 3:08 pm    Post subject: Reply with quote
"Whose on first"??........
In Nw York, the first subway trains did not operate until 1904.
However, ELEVATED trains in Boston began operating underground in 1901.
In 1901 (and until 1908) elevated trains* used the outer tracks of the Tremont St. subway; surface streetcars continued to use the center tracks.
Third rail was installed between the Haymarket and Pleasant St. portals, along with an automatic block signal system.
Subway station platforms were also rebuilt, to handle both elevated cars and surface trolleys.
The downfall of this "multi-mode" operation was that there was no through streetcar service between Park St. and Scollay Square; passengers between thee points had to transfer to the underground elevated trains, made for much rider inconvenience.
By 1908, streetcar service was restored through all parts of the subway, formerly served by the elevated trains.......
*Interestingly, these trains were often "mixed", with both gate cars and vestibuled cars in the same consists, making for quite interesting work for the harried platformen!
Last edited by NEW YORK OMNIBUS 2629 on Fri Oct 23, 2020 3:44 pm; edited 1 time in total
PostPosted: Fri Oct 23, 2020 3:26 pm    Post subject: Reply with quote
In Boston, several "El" stations once had ramps (w/loops) which brought surface streetcars up to station platform level, allowed streetcar riders a quick across-the-platform transfer to elevated trains.
One of the largest "transfer stations" was the massive Sullivan Square station, torn down not long after "El" service ended in 1975, featured a massive trainshed, that sheltered both El trains and streetcars; in later years, buses connected with the trains, on the same level.
In Brooklyn, B&QT once streetcars connected directly to elevated (subway) trains at the old Stillwell Avenue terminal.
The streetcar tracks here were stub-ended, and a crossover was also provided for the cars.
Too, the BRT/BMT "El" trains "rubbed shoulders" with the B&QT streetcars, passing through the cavernous Sands St. station.....
PostPosted: Fri Oct 23, 2020 3:41 pm    Post subject: Reply with quote
Sands St., many eons ago.......
https://www.nycsubway.org/perl/show?118067
PostPosted: Fri Oct 23, 2020 3:53 pm    Post subject: Reply with quote
A long-ago photo snapped at the elevated trolley terminal at Stillwell Avenue, showing a Peter Witt on the Norton's Point line.....
https://www.nycsubway.org/perl/show?141082
PostPosted: Fri Oct 23, 2020 4:01 pm    Post subject: Reply with quote
It is also interesting to note that elevated rapid transit came to Boston many years after the first elevated railways operated in New York (the Chicago "L" also once carried interurban trains of the CA&E and the NORTH SHORE)
The Boston "El" began operation in 1901, and was closed down in 1975; today, Chicago, New York, and Philadelphia still have elevated lines.
In New York, however, the remaining "Els" serve only subway trains; the Myrtle Avenue line, which closed in late 1969, was the last of the "traditional" Brooklyn elevated lines.
Though the 3rd Avenue El stopped running in Manhattan in 1955, the Bronx portion continued in operation until the early 1970's.......
Last edited by NEW YORK OMNIBUS 2629 on Wed Nov 06, 2024 12:00 am; edited 1 time in total
PostPosted: Fri Oct 23, 2020 5:46 pm    Post subject: Reply with quote
More "Boston Goes To Brooklyn"........
Note the collection of photos at the top of this page; these pictures show the ex-Boston (MBTA) PCC's that were to operate in Brooklyn a number of year back.
Sadly, this grandoise project fell through........
http://www.newdavesrailpix.com/nyc/brook.htm
PostPosted: Fri Oct 23, 2020 5:51 pm    Post subject: Reply with quote
A few more "Boston in Brooklyn" photos (Brooklyn Historical Railway Association).......
https://www.newdavesrailpix.com/nyc/htm/bhs01.htm
https://www.newdavesrailpix.com/nyc/htm/bhs05.htm
https://www.newdavesrailpix.com/nyc/htm/bhs12.htm
PostPosted: Fri Oct 23, 2020 6:02 pm    Post subject: Reply with quote
Historical note:
The ex-Boston PCC's seen in the previous selection of photos were known as "picture window" PCC's; these sleek and distinctive streamlined streetcars were not only the last new PCC's purchased for use in Boston (1951), they were also the last PCC's built by Pullman-Standard (these cars also featured air brakes, unique for the that era of new PCC's).......
Last edited by NEW YORK OMNIBUS 2629 on Wed Oct 25, 2023 11:00 pm; edited 1 time in total
Page 1 of 7
