Joined: 18 Dec 2007 Posts: 22646 Location: NEW JOISEY
Posted: Wed Oct 02, 2019 11:24 pm Post subject: |
MABSTOA #8557 at Lexington & 34th St., 1969 (also, a memorable year, indeed for the Amazin' New York Mets!)
Note the ad placards heralding the new "EXACT FARE" policy for the buses; the bus still carries its original (and smart!) "OA" insignia.....
http://bus.nycsubway.org/perl/show?1162
(courtesy: bus.nycsubway.org) |
Posted: Thu Oct 03, 2019 1:52 pm Post subject: |
MABSTOA #8571 (still sporting the old "TEE-YAY" green), at Broadway & 23rd St., 1974. *
http://bus.nycsubway.org/perl/show?1182
*This photo is interesting; while the front roller sign displays a reading for the "#M32", the sign over the reader door is set for the #15".
Until the mid-late 1940's, W. 23rd St. was a busy transfer point between streetcars (and later, buses) and the trans-Hudson ferries of several New Jersey railroads (ERIE/DL&W/CNJ); the "ELECTRIC FERRY" to Weehawken also docked here, until it was shut down in 1943)
The massive, clock-towered "UNION FERRY TERMINAL" (closely resembling the present 1907 Lackawanna terminal at Hoboken) was a hubbub of activity for many years.
By the early 1940's, the CNJ and the ERIE discontinued ferry service to W. 23rd St. from their respective Jersey City, leaving only the ferries of the DL&W; these boats continued to run until the service was abandoned, in late 1946.
Note a trace of this massive, monolithic terminal remains today........
Age: 70 Joined: 27 Feb 2013 Posts: 1059
Posted: Thu Oct 03, 2019 3:37 pm Post subject: |
The sidewalk where the bus is parked is on Fifth Avenue short of 23rd Street. That was the terminal, since 1925, for the route 15/M32/MQ32/Q32, Jackson Heights line until it was changed to West 32nd Street & 7th Avenue. |
Posted: Thu Oct 03, 2019 5:17 pm Post subject: |
MaBSTOA 15 wrote: | The sidewalk where the bus is parked is on Fifth Avenue short of 23rd Street. That was the terminal, since 1925, for the route 15/M32/MQ32/Q32, Jackson Heights line until it was changed to West 32nd Street & 7th Avenue. |
Thanks for the historical data....always greatly appreciated!
23rd St. had always been a busy transit thoroughfare; trans-Hudson ferries (until 1946), streetcars, several subway stations (including the H&M/PATH), and back in the day, El stations.
And, last, but certainly not least, buses.......
Age: 57 Joined: 02 Oct 2014 Posts: 2422 Location: New York, New York, USA
Posted: Thu Oct 03, 2019 5:32 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | 12th Avenue & 42nd St., 1971.
Here we see #8570 awaiting the next #M16 run.
Lost New York, certainly........
http://bus.nycsubway.org/perl/show?1178
Notice on 8570, the different 16 front sign from the '64 5300's; namely, a wider type font and '1 AVE'. |
Posted: Thu Oct 03, 2019 5:36 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | MABSTOA #8571 (still sporting the old "TEE-YAY" green), at Broadway & 23rd St., 1974. *
The front roll signs with small 'M' and bigger '32' would have been produced in April 1974, three months before what at this point was QM15 was to be rechristened M32. Unfortunately, the only 'updated' side signs for batwings I could see, were indicated with 'M16 Water-/side' and 'M41 Culture/Loop'. (Front slashes indicate the other part on a second line below the first.) The '15 Fifth Ave/Jackson Hts' would have dated to the 1966-67 group of batwing side signs from when OA 8301-8780 were built by GM. |
Posted: Thu Oct 03, 2019 5:46 pm Post subject: |
W.B:
Appreciate the info; I am not at all surprised to see that you had pertinent historical information to post here!
Through your many, many highly-informative responses (regarding roll signs past) here, it truly can be said that many vintage bus photos are indeed "worth a thousand words"......
Posted: Thu Oct 03, 2019 5:48 pm Post subject: |
12th Ave. & 42nd, 1981.
Recalling the days when WAMATA buses "pinch hit" for the MTA's ailing GRUMMAN fleet.......
http://bus.nycsubway.org/perl/show?2772
Posted: Thu Oct 03, 2019 5:54 pm Post subject: |
34th St. & 1st Avenue, 1973.
Here we see #8002 "on the job", holding down an "#M15" run.
As can be seen here, the era when many drivers were no longer wearing ties.
As is obvious from this photo, autos were QUITE large AND distinctive, back then.......(!!)
http://bus.nycsubway.org/perl/show?1662
Posted: Thu Oct 03, 2019 11:16 pm Post subject: |
Chatham Sq. & Mott St., 1972 (two Fishbowls on different routes for the price of one in this nostalgic view!)..........
http://bus.nycsubway.org/perl/show?2899
Last edited by NEW YORK OMNIBUS 2629 on Thu Oct 03, 2019 11:25 pm; edited 1 time in total |
Posted: Thu Oct 03, 2019 11:20 pm Post subject: |
Chatham Square in an earlier view; this scene (judging by the vehicles seen here) looks to have been taken not long before the venerable 3rd Avenue El was abandoned in Manhattan (1955)
Look closely on the extreme left; a bus can just be seen, in the shadows of the El structure.....
http://www.nycsubway.org/perl/show?96403
(courtesy:nycsubway.org)
Last edited by NEW YORK OMNIBUS 2629 on Thu Oct 03, 2019 11:33 pm; edited 1 time in total |
Posted: Thu Oct 03, 2019 11:32 pm Post subject: |
NYCTA MACK #5030 near Chatham Square, 1955 (note the shadows of the 3rd Avenue El above).........
http://bus.nycsubway.org/perl/show?3968
Posted: Fri Oct 04, 2019 1:03 am Post subject: |
NEW YORK OMNIBUS 2629 wrote: | 34th St. & 1st Avenue, 1973.
It looks like 8002 was a "loan" from the Fresh Pond ('FP') depot (as of 1/1/73), as what was generally based at the 126th Street ('MAN') depot was numbered in the 8123-8202 range. Someone once noted that one of the 5000's / 5100's (Flxible) was running on the M15; sounds like that too was "on loan" to MAN. |
Posted: Fri Oct 04, 2019 1:04 am Post subject: |
NEW YORK OMNIBUS 2629 wrote: | Chatham Sq. & Mott St., 1972 (two Fishbowls on different routes for the price of one in this nostalgic view!)..........
The bus running the M15 route was part of the 1960 'Tee-Yay' order, albeit a different numerical sequence than was first assigned to Manhattan TA depots in 1960-61. |
Posted: Fri Oct 04, 2019 10:17 am Post subject: |
W.B:
The subject of "loaner" buses, in itself, is an interesting topic.
I always find it interesting to read about buses being "shuffled" from one depot to another, over the course of their service years.
This also had to be interesting when buses were sent to another depot, and, lo and behold, they were not equipped with the appropriate roller curtain readings.
Again, greatly appreciate your always interesting and informative input.......
