Bus Alternator Expert
Busted
PostPosted: Fri May 10, 2019 1:45 pm    Post subject: Bus Alternator Expert Reply with quote
Hey All,
I'm new to the forum. and would appreciate your help.
I was wondering if the industry has an bus alternator guru? I'm working on an transit bus alternator issue and I'm looking for someone to tear down a failed alternator and give me a potential failure analysis. Are there any great service companies out there that could perform this for me?
If there is a better forum for me to post this inquiry in please let me know.
Thanks,
Chris
PostPosted: Sat May 11, 2019 8:42 am    Post subject: Reply with quote
Welcome to Bus Talk!
This forum is mainly for bus enthusiasts, so I don't know how likely you will find the information you seek, here.
I would suggest checking with one of the factory service centers of either the manufacturer of your bus, or of its engine...
Good luck! Smile
kdr3bt
PostPosted: Sat May 11, 2019 12:10 pm    Post subject: Reply with quote
Try the bus preservation and conversion forum
Runcutter
PostPosted: Sat May 11, 2019 4:40 pm    Post subject: Reply with quote
Chris, I'd suggest two sources, bulletin boards on which I'm active. Both deal with converted (motorhome) coaches, and some transits. There's a wealth of knowledge on maintenance and resources. One is the bulletin board hosted by Bus Conversions Magazine -- www.busconversionmagazine.com -- and the other is Bus Nuts Online --- busnut.com/forum
One of the first questions that will be asked is your location, since there may be a resource nearby (example, if you're near southern New Jersey, Luke Bonagura is the go-to guy for all maintenance issues).
Arthur
Runcutter
Arthur
Busted
PostPosted: Mon May 13, 2019 1:14 pm    Post subject: Reply with quote
Great and Thank you! This gets me a little bit closer.
Many Thanks!
GBL Rebel
PostPosted: Wed May 15, 2019 2:16 pm    Post subject: Reply with quote
A few questions:
What kind of bus?
What kind of alternator?
Where are you located?
Busted
PostPosted: Wed May 22, 2019 10:37 am    Post subject: Reply with quote
GBL Rebel,
Sorry. I just saw this. I was notified that I wouldn't have to follow through on the analysis so crisis averted.
Thanks for your response though!
GBL Rebel
PostPosted: Wed May 22, 2019 2:10 pm    Post subject: Reply with quote
Not a problem. If you want, my email is on the board if you have questions.
