PD-4102 vs. PD-4103
Post new topic   Reply to topic    BusTalk Forum Index -> Over The Road Carriers
PostPosted: Fri Jul 19, 2013 3:37 pm    Post subject: PD-4102 vs. PD-4103 Reply with quote
According to Brian Grams & Andrew Gold's book, GM Intercity Coaches 1944-1980 Photo Archive the difference between both models was engineering changes at the request of Greyhound.
Structurally they were the same including the rear windshield, correct?
PostPosted: Fri Aug 09, 2013 9:08 am    Post subject: Reply with quote
I believe this is correct. Only 116 PD4102's were built. I've seen three of them, all from different operators. The rear window was the same as on the PD4103. I have been told there was a difference in some vent openings on each side above the windows just behind the driver and the entrance door. Other than that, I believe they were identical.
I have seen statements on other forums from time to time that the PD4102 had the same rear window setup as the PDA4101. In other words, GM transit rear windows. Based on the three buses I saw, I think that is in error.
Roy
PostPosted: Fri Aug 09, 2013 7:03 pm    Post subject: Reply with quote
Roy,
Thanks for confirming my thoughts.
Post new topic   Reply to topic    BusTalk Forum Index -> Over The Road Carriers All times are GMT - 5 Hours
