Vintage Suffolk County Coach Buses
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
S-60 To Smith Haven Mall
PostPosted: Thu Jul 14, 2011 9:22 pm    Post subject: Reply with quote
Small update to Sunrise Coach in the last roster update
The TransitMan
PostPosted: Sun Jul 17, 2011 7:13 pm    Post subject: Reply with quote
A couple of changes for Hampton Jitney:
#56 is a H3-41
#90 is a H3-45 (meaning that there is NO X3-45 #90)
#106 is an X3-45
Will keep looking out for more. Nice list here, Mac!
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Sun Jul 17, 2011 11:34 pm    Post subject: Reply with quote
As of 7/18/11
Thanks to Transit Man for his Info
*Some buses may not fit the word Vintage due to their age, let me know if they should be removed from the list, also I believe a age should be selected to designate a bus as vintage*
(Active Bus Companies on top, Disbanded Companies on bottom)
Inter County Motor Coach
1958 GM PD-4104: 120 (Sent to Lincoln Transit NJ)
1958 GM PD-4104: xxxx
1972 GM P8M-4905A: 290
1973 GM P8M-4905A: 434
1974 GM P8M-4905A: 330-332 (#330-331 came two buses before #332)
1975 GM P8M-4905A: 1776
1975 GM P8M-4905A: 1776B
1976 GM P8M-4905A: 446
1977 GM P8M-4905A: 445-444
1979 MCI-9: 602 (Sent to Oak Tree Bus Service as #77)
19xx -------: 615
Hampton Jitney Bus
1993 Prevost H3-40: 47
1994 Prevost H3-40: 50
19xx Prevost H3-45: 63
1997 Prevost LeMirage XL: 92 (Ex Sunrise Coach)
1998 Prevost LeMirage XL: 93-94 (Ex Sunrise Coach)
1999 Prevost LeMirage XL: 95 (Ex-Sunrise Coach)
2000 Prevost H3-45: 96-97 (Ex Sunrise Coach)
2001 Prevost LeMirage XL II: 98-99 (Ex Sunrise Coach)
2002 GCA Freightliner: 100 (Ex Sunrise Coach)
2002 Prevost LeMirage XL II: 101 (Ex Sunrise Coach)
2003 Prevost LeMirage XL II: 102 (Ex Sunrise Coach)
2004 Prevost LeMirage XL II: 103 (Ex Sunrise Coach)
2004 Prevost H3-45: 104 (Ex Sunrise Coach, is in a Gold Paint Scheme)
2005 Prevost H3-45: 105 (Ex Sunrise Coach)
2006 Prevost LeMirage XL II: 106 (Ex Sunrise Coach)
xxxx MCI F3500: 88
xxxx Prevost LeMirage XL-II: 90
xxxx Prevost Model H3-41 #47,50-51,55-56
xxxx Prevost Model X3-45 #80,84,86,89,107-108,112,118-122 (#112 and #118-122 are in the Ambassador Scheme...and yes there are more for that service.)
xxxx Prevost Model H3-45 #60,62-65,71,73,75,77,85,87,90 110-111
Sunrise Coaches Inc.
1954 GM PD-4104: 45 (Ex Monumental Tours of Baltimore, MD. Unknown number when run at Monumental Tours)
1964 GM PD-4106: 103
1981 Prevost LM-103: 300-301 (Both came in May of 1981?, but #300 was built before #301)
[color=red]1997 Prevost LeMirage XL: 329 (Went to Hampton Jitney # 92)
1998 Prevost LeMirage XL: 331-332 (Went to Hampton Jitney # 93-94)
1999 Prevost LeMirage XL: 334 (Went to Hampton Jitney # 95)
2000 Prevost H3-45: 336-337 (Went to Hampton Jitney # 96-97)
2001 Prevost LeMirage XL II: 338-339 (Went to Hampton Jitney # 98-99)
2002 GCA Freightliner: 403 (Went to Hampton Jitney # 100)
2002 Prevost LeMirage XL II: 340 (Went to Hampton Jitney # 101)
2003 Prevost LeMirage XL II: 341 (Went to Hampton Jitney # 102)
2004 Prevost LeMirage XL II: 342 (Went to Hampton Jitney # 103)
2004 Prevost H3-45: 343 (Went to Hampton Jitney # 104, Has Gold and Blue Lettering)
2005 Prevost H3-45: 344 (Went to Hampton Jitney # 105)
2006 Prevost LeMirage XL II: 345 (Went to Hampton Jitney # 106)
In Active Bus Companies
Coram Bus Service
1974 GM P8M-4905A: 118
1975 GM P8M-4905A: 125
1976 GM P8M-4905A: 127
1977 GM P8M-4905A: 128
Harran Transportation
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, 515 went to Private Transportation)
1981 MCI-9: 519,553,565 (#565 is now a bus for a church in Wyananch)
1983 MCI-9: 569
1989 Eagle Model 15: 600-601,605
xxxx Eagel Model 10: 536
xxxx Eagle Model xx: 523
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815
xxxx Prevost xx-xx: xxx (Space Shuttle Paint scheme)
Last edited by S-60 To Smith Haven Mall on Thu Sep 29, 2011 12:19 pm; edited 2 times in total
The TransitMan
PostPosted: Tue Aug 23, 2011 5:58 pm    Post subject: Reply with quote
Ok. A couple of things, add X3-45 #107-108 to the Hampton Jitney list. Also, you have numbers listed twice. Hampton Jitney does not have two buses with the same number on them.
I will look for the NEW Prevost H3-45s. I do believe they are numbered in the 120s but I will get back to you on that.
PostPosted: Tue Aug 23, 2011 7:08 pm    Post subject: Reply with quote
I didn't notice, I'll make the edits to the list above
PostPosted: Thu Sep 29, 2011 3:25 pm    Post subject: Reply with quote
As of 9/29/11
Thanks to Hart Bus
19xx -------: 615
Hampton Jitney Bus
xxxx MCI F3500: 88
xxxx Prevost Model H3-45 #60,62-65,71,73,75,77,85,87,90, 110-111
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
PostPosted: Mon Oct 03, 2011 4:52 pm    Post subject: Reply with quote
As of 10/3/11
Thanks to Hart Bus
19xx -------: 615
Hampton Jitney
19xx Eagle Model xx: 30
xxxx MCI F3500: 88
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
PostPosted: Thu Nov 24, 2011 1:21 pm    Post subject: Reply with quote
As of 11/23/11
Thanks to Hart Bus
19xx -------: 615
Hampton Jitney
xxxx MCI F3500: 88
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1982 Eagel Model 10: 536
1983 MCI-9: 569
1989 Eagle Model 15: 600-601,603-604,605
xxxx MCI 96A2: 607
PostPosted: Wed Feb 01, 2012 12:59 pm    Post subject: Reply with quote
As of 2/1/12
xxxx MCI-9: 607
19xx -------: 615
Hampton Jitney
xxxx MCI F3500: 88
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
1989 Eagle Model 15: 600-605
xxxx MCI 96A2: 607
PostPosted: Tue Feb 07, 2012 10:41 pm    Post subject: Reply with quote
As of 2/12/12
xxxx MCI-9: 607
19xx -------: 615
Hampton Jitney
xxxx MCI F3500: 88
2004 Prevost H3-45: 343 (Went to Hampton Jitney # 104, it once had a Gold paint scheme with Blue Lettering)
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1974 P8M-4905A: 504-505
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
Last edited by S-60 To Smith Haven Mall on Sun Feb 12, 2012 11:48 am; edited 2 times in total
The TransitMan
PostPosted: Sun Feb 12, 2012 8:19 am    Post subject: Reply with quote
Hampton Jitney's "GOLDEN" bus is no more. Bus #104 is back the original scheme. Saw it this morning as I arrived to work.
PostPosted: Sun Feb 12, 2012 11:48 am    Post subject: Reply with quote
May change to the roster above.
The TransitMan
PostPosted: Sun Mar 18, 2012 8:32 pm    Post subject: Reply with quote
S-60 To Smith Haven Mall wrote:
As of 2/12/12
Hampton Jitney
xxxx MCI F3500: 88
Since I work along County Road 39 and I pay a visit to Hampton Jitney Depot almost regularly, here's an "ALMOST" complete roster. I don't know the year of the bus BUT I'll base it on what is on the roster, which is close enough. By the way, ALL NUMBERS CONFIRMED. Here we go!
1993-1994 H3-41 #47, 50-51, 55-56
1997-1999 Le Mirage #92-95
Now the H3-45 in various years:
56, 60, 62-67, 70-72, 74-79, 81, 85, 90, 96-97, 104-105, 108, 110-111, 114-115, 120, 123-124
NOTE: 74 and 76 are wrapped, 114-115 are the NEWEST H3-45 with the NEW scheme.
Now the X3-45 in various years:
80, 84, 86, 89, 91, 98-99, 101-103, 106-107, 112-113, 117-118, 121-122
NOTE: #91, #112, #117-118, #121-122 are in the Ambassador Scheme...however, I have not seen #91 in a long time.
Also, #113 has the sign destination sign similiar to the MTA NYCT's Prevost.
So I hope this helps! I will be looking out for more. mac5689, adjust your roster because you have numbers listed twice (like #90 and #108 in both H3 and X3)
Last edited by The TransitMan on Sun Mar 18, 2012 8:34 pm; edited 2 times in total
The TransitMan
PostPosted: Sun Mar 18, 2012 8:33 pm    Post subject: Reply with quote
Oh and Hampton Luxury Liner....
X3-45 #2701-2713 and #2801-2806...as far as I know with the #2800s.
PostPosted: Sun Mar 18, 2012 10:49 pm    Post subject: Reply with quote
As of 2/12/12
Hampton Jitney
xxxx MCI F3500: 88
Maybe the Prevost LeMirage XL-II #90 was a older model and was retired or was sold off before getting H3-45 #90?
I haven't seen a second bus #108 can you point it out to me?
Page 2 of 10
