Age: 52 Joined: 02 Oct 2014 Posts: 341 Location: New York, New York, USA
Posted: Fri Feb 17, 2017 12:09 pm Post subject: |
andy47 wrote: | With regard to the photo of the NYCO Model 728 under the (demolition underway) 9th Avenue El, the Route 5 on the roll sign is not today's M5 Fifth/Sixth Aves/Riverside Drive route, which was FACO's old Rte 5. The bus is on NYCO's 5/Sixth Avenue route, which operated between 59th Street and Lower Manhattan on Sixth Ave. and Church Street. MABSTOA inherited this route in 1962, only to end it in 1963 when Broadway and Sixth Avenue below 14th Street were combined into a one-way pair. The Route 6/Broadway took over both directions and the Rte 5 was eliminated.
Funny thing is that even though FACO and NYCO were under common ownership their routes used duplicative route numbers, even though parallel routes with the same number were often a block apart - such as the two #5 routes, and the #2 routes on both Fifth and Madison Aves. The advent of MABSTOA and the one way avenue operations put an end to most of that and today there are no duplicative numbers in Manhattan.
Also - a point of irony - in 2010 when there were route cuts and combos in Manhattan, the M6 was eliminated completely, and the M5 was extended from Houston Street to South Ferry to cover the southern part of the M6. It is now probably the longest route in Manhattan - from 178th Street to South Ferry. The M101 was the longest when it ran to City Hall, but its south terminal is now 6th Street. |
At what point did the ex-FACCO #5 have its northbound route shifted to Sixth Avenue between Houston Street and 57th Street - I presume it was the point Fifth Avenue became one way southbound on Jan. 14, 1966?
There was another irony to the 2010 route overhauls. Since '66 the M1 had been largely ex-NYCO, with the southbound route of Fifth Avenue between 135th and 40th Streets being practically the only vestige of FACCO's #1. But after 2010, the M1 was rerouted to Madison Avenue north of 25th Street - and all the way down Fifth Avenue up to 8th Street. That is where you see the southbound route more in line with FACCO's old #1. |
Posted: Fri Feb 17, 2017 12:14 pm Post subject: |
Mr. Linsky wrote: | Here's then New York City Mayor Edward I. Koch (in shirtsleeves) in a shot dated May 16th. 1979 launching his "New York's Doing It' campaign to encourage New Yorker's to use public transportation.
If you've assumed that the posed bus (operating for the Manhattan and Bronx Surface Transit Operating Authority - MaBSTOA) is a GM New Look look again because it's a Flxible and probably a Model 53102 very recently delivered in view of its pristine condition.
BTW; how do I know it's a Flxible - what's the giveaway?
It's amazing that they were already thinking 'green' in those days.
Photo courtesy on the New York City Archive.
I could swear the guy on the right was the late Queens Borough President Donald Manes . . . besides, the small window gives this away as from the 1977 orders. |
Age: 68 Joined: 24 Apr 2007 Posts: 1126
Posted: Fri Feb 17, 2017 2:44 pm Post subject: |
It could be Manes as BP of Queens, before his suicide. But I always thought that he had a conventional haircut, not the long hair and sideburns, but I could be wrong |
Posted: Fri Feb 17, 2017 2:45 pm Post subject: |
Posted: Fri Feb 17, 2017 4:43 pm Post subject: |
Hart Bus wrote: | It could be Manes as BP of Queens, before his suicide. But I always thought that he had a conventional haircut, not the long hair and sideburns, but I could be wrong |
By the '80's, and up to the point of his death, Manes' haircut was indeed conventional. |
Posted: Fri Feb 17, 2017 4:48 pm Post subject: |
frankie wrote: | Great find Mr. L! I always love riding these buses on the B-60 route when I was growing up. When seated at the rear, those long rear overhangs made a wonderful amusement ride along those bumpy Brooklyn streets.
And speaking of Ralph Kramden, we're all familiar with the famous photos of him behind the wheel of 2969 - once shot with Alice, Trixie and Ed peering out the windows behind Ralph and the other of Alice about ready to hand Ralph his lunchbox.
The question is, does anyone know what route Ralph's 2969 was signed for? Well here's the answer along with another Ralph pose in a lesser known and rarely seen publicity photo. His two other famous photos never show the destination.
Personal head scratcher! How is it that those destination sign makers couldn't fit an "O" in Madison?
Top photo courtesy of unknown source from Facebook; Bottom photo courtesy of Hollywood Historic Photos for educational purposes only.
It was NYCO's route 2 - which, along with NYCO #1, was assigned back then out of 100th Street depot, as was NYCO #18 (later designated M18, now M86 Select Bus Service) on which 2969 ran for much of its active life (well into MABSTOA days). Wonder if the '2A' designation was for FACCO's route to distinguish from NYCO's, or the other way around? |
Posted: Sat Jun 24, 2017 5:54 pm Post subject: |
Mr. Linsky wrote: | # 7141's paint scheme is very much the same as the last 90 GM TDH 5106's purchased by Fifth Avenue Coach Lines in 1959 with 40 of those going to affiliate Surface Transit (see Fifth Avenue # 2667 below).
Based on the Five Fingered Exercise ad up front, and the cigarette ad on the side, I'd venture this pic to be between Dec. 1, 1959 (when the play opened at the Music Box Theatre) and Oct. 1, 1960 (when it closed). I don't think that TDH-5106, when first delivered to FACL, had ad placeholders anywhere on the exterior. (And this color scheme was also on the 1958-59 Mack C-49's and GM TDH-5106's ordered for Surface Transit.) |
Age: 61 Joined: 17 Apr 2007 Posts: 1658 Location: Central NJ
Posted: Sat Jun 24, 2017 6:40 pm Post subject: |
That is one beautiful bus  |
Posted: Sat Jun 24, 2017 9:40 pm Post subject: |
Mr. Linsky wrote: | Taken at Church and Murray Streets in downtown Manhattan circa 1941, the below image shows fleet number 738 - a 1937 Yellow Coach Model 728 and one of 268 (501 to 768) operating for the New York City Omnibus Corporation.
The versatile and popular 36 passenger 728 boasted an improved 479 cubic inch gasoline engine mounted transversely in the rear with a patented 'angle drive' accompanied by a mechanical transmission with almost 600 produced between 1935 and 1939 when it was replaced by the far more recognizable Model 740.
Number 738 is seen on the newly acquired routes of the Triangle Bus Corporation.
What is perplexing to me is the fact that 738 is signed as the Number 5 Fifth Avenue line which may have been an extension from 57th. Street to the Battery.
Notice the elevated structure which was a remnant of one of the first steam engine powered lines in Manhattan.
Photo courtesy of the New York City Archives.
This 5 was NYCO's Sixth Avenue route, wholly unrelated to FACCo's Route 5 - Fifth Avenue/Riverside Drive. NYCO 5 lasted all the way till Nov. 10, 1963 after which it was discontinued and absorbed into the heretofore Broadway/7th Avenue NYCO 6 - whose northbound route thereafter (until its own 2010 demise) ran through Trinity Place, Church Street and Sixth Avenue (whose entire route south of Herald Square completed its conversion to one-way northbound at that point). |
Posted: Sat Jun 24, 2017 9:43 pm Post subject: Re: 'VINTAGE NEW YORK CITY' |
Mr. Linsky wrote: | Here's another one of those marvelous vintage street scenes from Manhattan.
Pictured, circa mid sixties, is the intersection of 3rd. Avenue and 42nd. Street showing an early non-air conditioned 5300 GM New Look flagged for the Manhattan and Bronx Surface Transit Operating Authority (MABSTOA) crossing what I believe is 42nd. Street (if I remember correctly, 3rd. Avenue had the peculiar fluorescent street lights at that time).
So, if I am correct, the unidentifiable Mack in the same image is sitting at a bus stop on 3rd. (I say unidentifiable because I am uncertain as to whether it might be ex Surface or ex B.O.T.).
However, I'll leave it up to my learned New York colleagues to better interpret the scene.
Enjoy!
Photo courtesy of New York City archives.
If the Mack's up Third Avenue, then it would've been ex-Surface. How many of the 1963 order (3301-3555) did Manhattan depots and bus routes run by MaBSTOA get initially? I know a lot of that first order for MaBSTOA went to the Bronx to replace the most dilapidated of the ex-Surface Macks and GM Old Looks. |
Posted: Sat Jun 24, 2017 9:55 pm Post subject: |
Hart Bus wrote: | When did FACC and/or its affiliated companies get routes on 6th Avenue? I am looking at a repo of booklet entitled " Fifth Avenue Coach Routes and Vistior's Guide" reprinted in 2005 to commerorate the 100 anniversary. It shows the routes of FACC in 1939-1940 with the extension of the #15 to the World's Fair. There is no route shown operating on "Sixth Avenue". |
I don't know if I mentioned it, but the only FACCo route to travel up Sixth Avenue, did so long after successor operator Fifth Avenue Coach Lines was deposed and operations taken over by MaBSTOA: the Fifth Avenue-Riverside Drive (M)5. It took place in two stages:
a) On Nov. 10, 1963 - the day Sixth (Avenue of the Americas) south of Herald Square became one-way northbound, and Broadway between Herald and Madison Squares and from Union Square to Canal Street went one-way southbound - the 5's southern terminus was extended further southbound to Houston Street and West Broadway. This required the line, south of Fifth and 8th Street, to travel east on 8th, south on Broadway and west on Houston to its terminus (technically at La Guardia Place, but that nomenclature wouldn't have fit on the roll signs, I suppose); then heading on its northbound trek, further west on Houston, north on Sixth, and then east on 8th towards Fifth. (Side note: Effective Sept. 2, 1963, the former terminus of today's M2, M3 and M5, Washington Square Park, was closed to bus traffic; from then to Nov. 10, those lines terminated at 8th Street just east of Fifth Avenue, and then traveled east on 8th, north on University Place and west on 9th Street for the northbound trek through Fifth.)
b) On Jan. 14, 1966, when Fifth and Madison Avenues were converted to one-way traffic, the 5's northbound route was shifted to the rest of Sixth below 57th Street. It was thus the only Fifth Avenue route of the ex-FACCo network not to be moved northbound to Madison. |
Posted: Sat Jun 24, 2017 10:01 pm Post subject: |
Mr. Linsky wrote: | Fellows,
I was thinking about checking to see whether any of those stores still exist - the old phone books would be a great idea too.
Buses that are usually involved in campaigns of any sought have some kind of banners especially under the window belt as pictured below on NYCO # 260 (location unknown - but might be on Lexington Avenue).
Oh, it's Lexington all right - the Lexington/Lenox route 4, which ran until the 1960 one-way conversions of Lexington and Third Avenues, after which Surface Transit's M-101's southbound path was shifted to Lexington. (Not until 1969, with the launch of M-101A [today, M102], would buses travel to Lexington from Lenox again - and for the first time, from Third to Lenox.) |
Posted: Sat Jun 24, 2017 11:35 pm Post subject: |
Mr. Linsky wrote: | X-A,
Thanks for the update and the great map.
Here's a couple of NYCO maps that might interest you.
Enjoy,
It looks from that, that Routes 21 (Houston Street and Avenue C Crosstown) and 22 (Pitt and Ridge Streets) didn't come under NYCO purview until about 1946 or '47. I take it 22 was one of the four routes that were discontinued between the onset of the 1962 strike against Fifth Avenue Coach Lines, and the resumption of service under MaBSTOA? (The other three being FACCo's 1 - Fifth Avenue and 19 - Fifth Avenue/Riverside Drive; and Surface Transit's M-105 - Tenth Avenue.) |
Posted: Sat Jun 24, 2017 11:41 pm Post subject: |
Mr. Linsky wrote: | You might notice that most photos of vintage Fifth Avenue Coaches are taken in and around Washington Square Park which was the fashionable thoroughfare's southern most terminus and the end or the beginning (depending on which way you look at it) of no less than five of the company's very prestigious routes including the 1, 2, 3, 5, and 19 with northern terminations at various points in both upper Manhattan and Harlem.
So, it's of no surprise to once again see the Square as the colorful backdrop for fleet number 2414 - a 1950 GM Model TDH 4509 and one of 74 (2363 to 2437) purchased by the company in June of that year.
Number 2414, signed for route #2, is very new in this image and still sports its original and trademark Omnibus two-tone green and cream livery which would eventually change to a very plain green and cream wrapper.
The arch in the background, which dates to 1889, was originally constructed of wood in celebration of the centennial of George Washington's inauguration as president and was so well received that it was rebuilt in granite as a permanent monument in 1889.
Photo courtesy of Flickr.
After the 1962 strike against Fifth Avenue Coach Lines and Surface Transit, and the takeover of all their routes by MaBSTOA, Routes 1 and 19 disappeared from the itinerary, thus leaving only 2, 3 and 5 to terminate there. By mid-1963 a few of the newly-ordered MaBSTOA TDH-5303's numbered within the 3301-3555 range would stop along that loop. Those would be among the last buses to travel through the park, as effective Sept. 2, 1963 Washington Square was officially closed to all bus traffic, leading to massive reroutings and shiftings of the southern termini. |
Posted: Sat Jun 24, 2017 11:45 pm Post subject: |
Mr. Linsky wrote: | The color photo below has a dual value in not only espying a bit more of the history of New York surface transportation but as an important piece of Manhattan's own past.
The intersection is that of Washington Square North and Fifth Avenue just across from the entrance to Washington Square Park in a snapshot taken sometime not long after Fifth Avenue Coach was absorbed into the newly formed Manhattan and Bronx Surface Transit Operating Authority (MABSTOA) in 1962.
Two generations of GM Coaches are seen heading south on Fifth toward the park and both flagged for MABSTOA with the first presumed to be either an ex Transit Authority or Fifth Avenue 5100 Model followed by a newly purchased 5300 series.
Before the mid nineteenth century, Washington Square North was considered to be 'uptown' Manhattan with little more than grasslands, meadows and an occasional farm house beyond and the fashionable upper Fifth Avenue with its marble mansions and exquisite shops then being only a drawing board concept for the future.
It was in this era that the captains of industry of the borough built themselves the elegant townhouses that can still be seen as landmarks dotting the perimeter of the park with one of which taking center stage in our image.
Notice that the Greenwich Village artist colony shows its wares along the historic strip on a sunny weekend afternoon.
Photo courtesy of eBay.
That 5300 series 'fishbowl' - anyone sure that ain't one of the 5303's that were the first ordered specifically for MaBSTOA and delivered in mid-1963? It was in that year, after all, that all 'old looks' were painted in the two-tone green already in place on TA rolling stock, and the 120 'Fishbowls' ordered by Fifth Avenue Coach Lines in 1960 for both it and Surface Transit painted in the same scheme as the TA's 'New Looks'. And those colors are in evidence here.
The historical significance is even more so, as Washington Square was closed to all bus traffic effective Sept. 2, 1963, hence these were among the last to pass through there. |
