Where Did the Old Green Line Buses Go?
Post new topic   Reply to topic    BusTalk Forum Index -> New York City Bus Rosters
PostPosted: Sun May 13, 2007 1:40 am    Post subject: Where Did the Old Green Line Buses Go? Reply with quote
I am briefly listing below the final dispositions of a number of vintage Green Line Buses for your edification and record;
1933 Mack Model 6BC3S;
#411 To; B and B Bus Service
1933 Mack Model 4AB3S;
#421 To; Blue Bus Lines as #16
1935 Mack Model 6CX3S;
#522 & 528 To; Avenue 'B' Transit as # 239 & 240
1937 Mack Model 6CT3S;
#604, 606, 607, 609 & 621 To; Valley Transportation Company renumbered to 153, 150, 154, 152 & 155 respectively.
The records reflect nothing concerning #701 to 735 1938 Mack CT3G's
1939 Mack Model CM3G;
#803, 808, 810, 815 and 822 To; Jamaica Buses renumbered as 20 thru 24 respectively.
#101, 102, 103. 104, 106, 108, 109, 111, 112, 113, 114, 116, 117,119, 121, 123, 126, 127 and 130 (ex Manahattan and Queens) To; Jamaica Buses using same numbering.
1946 GMC Model TD4506;
#201 thru #209 (ex Manhattan and Queens) To; Jamaica Buses using same numbering.
#901, 903, 905, 906, 908, 909, 910, 911, 912, 915, 920, 922 and 925 To; Jamaica Buses renumbered as 210,211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 223 and 222 respectively.
1947 GMC Model TDH4507
#934, 936, 938, 939, 943 and 946 To; Jamaica Buses numbered as 224, 225, 226 229, 228 and 230 rspectively.
1949 GMC Model TDH4507;
#301 thru 310 To; Reading Bus Company, Reading, Pa. as #'s 800 to 809 respectively.
1950 GMC Model TDH4509;
#311, 316, 321,325, 327, 329, 334, 338 and 342 To; Jamaica Buses renumbered as; 401, 412, 405, 415, 407, 416, 408, 409 and 420 respectively.
#315, 320, 326 and 332 To; Buddy's Transportation Company renumbered 703, 702, 700 and 701 respectively.
#323, 328, 331 and 345 To; Conestoga Transportation Company renumbered as 358, 359, 360 and 361 respectively.
#333 and 343 To' Peninsula Bus Company - 333 renumbered to 209, 343 remained same number.
#341 To; Reading Bus Company, Reading, Pa. renumber unknown.
1952 GMC Model TDH5104;
#351, 352, 353, 354, 355, 356, 358, 359, 361 and 365 To; A B & W Transit Company renumbered as 601, 602, 603, 604, 605, 606, 607, 608, 609 and 610 respectively.
#357 To; Jane E. Silberstein (NJ) renumbered B157
#360 To; Ronald A. Englehardt (NJ) renumbered to B103
#362 To; Cheswick Transit Company as # 51
#364 To; Kenneth Englehardt (NJ) renumbered as B126
1954 GMC TDH4512;
#106 To; Copa Bus Company as Number 72
#107 To; Dominick Raimando, Inc. (NJ) as # B52
#108 To; Montgomery Bus Corp. as # 273
#110 To; JRM Bus Company (NJ) as # B55
#112 To; Hoboken Transportation (NJ) as # 7
#114 To; Edward D. Smith Bus Company (NJ) as # 25B
#115 To; J S Bus Corporation (NJ) as # B44
Note; other buses from this group did go to Kent State University Campus Bus Service but are not reflected in the record.
1959 GMC TDH5106;
#151, 153, 154, 155 and 158 To; Chicago & Calumet District Transit Company renumbered 2974, 2975, 2976, 2977, 2978 respectively.
#152 and 157 To; Rockford Transit Corporation as #'s 2972 and 2973
#156, 159 and 160 To; Philadelphia Suburban Transportation Company renumbered as 250, 251 and 252 respectively in 1967.
1960 GMC Model TDH5301 (New Looks);
#401, 402, 403 and 404 To; Avenue 'B' Transit renumbered to 507, 508, 509 and 510 respectively.
#406, 407, 408 and 409 To; Denver Metro renumbered as 101, 102, 103 and 105 respectively.
#412, 413, 414, 415 and 416 To; Pioneer Bus Corporation using same numbering.
Records courtesy of the late Don Weiss of the Motor Bus Society and Green Bus Lines archive.
"the Green Hornet"
Green Bus Lines, Inc., Jamaica, New York
PostPosted: Sun May 13, 2007 3:20 pm    Post subject: Reply with quote
Nice; thanks Mr. L!
foto_buff
PostPosted: Tue Jun 26, 2007 9:09 pm    Post subject: Where Did the Old Green Line Buses Go? Reply with quote
#311, 316, 321,325, 327, 329, 334, 338 and 342 To; Jamaica Buses renumbered as; 401, 402, 411, 403, 412, 404, 413, 405, 406, 415, 407, 416, 417, 408, 419, 409, 410 and 420 respectively.
I see only nine GBL numbers showing and 18 Jamaica Bus numbers. I think some data is missing. Can you check this?
Thanks and best regards,
Vince
vsyrek@optonline.net
PostPosted: Wed Jun 27, 2007 1:15 am    Post subject: Re: Where Did the Old Green Line Buses Go? Reply with quote
Vince
Vince,
Sorry about that - let me look at my records as we speak! (intermission).
O.K. - this is the correction (which I will make in the main body of the report);
311, 316, 321, 325, 327, 329, 334, 338 & 342 to Jamaica as 401, 412, 405, 415, 407, 416, 408, 409 and 420 respectively.
My only excuse is that when you deal with these numbers and lists so late at night, you eventually dizzy from them!
Again, sorry for the error and thanks for the heads up!
"The Green Hornet"
Green Bus Lines, Inc., Jamaica & Arverne, New York
PostPosted: Mon Aug 13, 2007 3:25 pm    Post subject: Re: Where Did the Old Green Line Buses Go? Reply with quote
1954 GMC TDH4512;
1959 GMC TDH5106;
#151, 153, 154, 155 and 158 1959 To; Chicago & Calumet District Transit Company renumbered 2974, 2975, 2976, 2977, 2978 respectively.
#156, 159 and 160 To; Philadelphia Suburban Transportation Company renumbered as 250, 251 and 252 respectively.
"the Green Hornet"
An addendum to the above listing;
Newly obtained information will complete the TDH 4512 catagory as follows;
1954 GMC Model TDH 4512;
#101 (Ser# 0548) to; Kent State University Campus Bus Svc. as # 1545
#102 (Ser# 0549) to; Kent State University Campus Bus Svc. as # 1234
#103 (Ser# 0550) to; Kent State University Campus Bus Svc. as # 1434
#104 (Ser# 0551) to; Kent State University Campus Bus Svc. as # 1745
#105 (Ser# 0552) to; Kent State University Campus Bus Svc. as # 1644
#109 (Ser# 0556) to; Kent State University Campus Bus Svc. as # 1134
#111 (Ser# 0558) to; Kent State University Campus Bus Svc. as # 1334
All of the above were sold to Kent State in 1967.
An interesting aside; these people must have known what they were doing because in addition to Green Line's above 4512's they also bought five from Santa Monica Municipal Bus and one from M. K. & O. Transit of Tulsa Oklahoma.
This gave them an initial fleet of what were probably the 'best' buses ever built!
"The Green Hornet"
Green Bus Lines, Inc., Jamaica & Rockaway, New York
Post new topic   Reply to topic    BusTalk Forum Index -> New York City Bus Rosters All times are GMT - 5 Hours
