"Green Hornets"/"Ls"/Interurbans
Goto page Previous  1, 2, 3 ... 18, 19, 20
PostPosted: Thu Feb 05, 2026 12:50 am    Post subject: Reply with quote
(SEE PREVIOUS POST/LINKS)
The BMT "Zephyr"..........
Also from the early 1930s was the sleek, shiny articulated "ZEPHYR"; this modern unit was also designed to replace antiquated wooden El cars on the BMT's Brooklyn elevated lines.
It also featured florescent lighting, QUITE futuristic at that time.
Unlike the "GREEN HORNET", the BUDD-built "Zephyr" had a decent service life, and ran until 1954.......
https://www.nycsubway.org/perl/show?75915
https://www.nycsubway.org/perl/show?46944
https://www.nycsubway.org/perl/show?112948
(courtesy:nycsubway.org)
["16 CANARSIE"]
PostPosted: Thu Feb 05, 2026 1:26 pm    Post subject: Reply with quote
Further:
On this day in 1941, the BMT's "GREEN HORNET" was removed from revenue service on the #7 Franklin Avenue shuttle in Brooklyn; as I had noted previously, this aluminum-bodied trainset was scrapped in 1942, after lying idle in the BMT shops for some time, awaiting spare parts.......
["7"]
PostPosted: Thu Feb 05, 2026 1:36 pm    Post subject: Reply with quote
Here is a rare photo of the once-proud "GREEN HORNET", undergoing scrapping, photographed in the BMT's shops...........
https://www.nycsubway.org/perl/show?46924
["B.M.T. LINES"]
PostPosted: Thu Feb 05, 2026 3:07 pm    Post subject: Reply with quote
Too bad such a short life for the Green Hornet. It was a good looking train.
PostPosted: Thu Feb 05, 2026 4:48 pm    Post subject: Reply with quote
Cyberider:
Had then-Mayor La Guardia (who was also a VERY staunch foe of streetcars!) not been so determined to rid the City of its elevated lines, there is a good chance that more modern lightweight articulated trains (such as "The Green Hornet" and the "Zephyr") might have been built,to modernize the BMT's complex network of elevated lines in Brooklyn.
It should also be noted that the BMT was the only company in New York to operate articulated trains; the "Mult-Sections" ran from 1936 to 1961, and the "D"-type "Triplex" units (which I remember) operated from 1925 until 1965.
More on these unique articulated subway trains later.....
["4 CONEY ISLAND"]
PostPosted: Thu Feb 05, 2026 10:06 pm    Post subject: Reply with quote
The fearsome and hulking BMT "Triplex" units entered service in 1925;these were the BMT's first "production mode;" articulateds.
These units were also the first in New York to use illuminated end roller signs.
They gave decades of solid, reliable service until retirement in 1865 (thankfully, Mom and I rode these rail-bound battleships, way back in the day! Very Happy
They last ran on the Astoria line in 1965............
https://www.nycsubway.org/perl/show?26383
https://www.nycsubway.org/perl/show?150753
https://www.nycsubway.org/perl/show?6572
["5 CHAMBERS STREET"]
PostPosted: Thu Feb 05, 2026 10:29 pm    Post subject: Reply with quote
The last articulated trains built for the BMT were the quick-steppin' "Multi-Section" units; built by ST. LOUIS and PULLMAN-STANDARD; the first entered service in 1936.
These trains (originally designed for eventual conversion to one-man operation, were the first in New York to feature the now-standard full-width cab.
They also were novel in that they featured chain-driven station announcement signs (located over the passageways between units), which featured metal sign plates operated by a unique "carousel" arrangement.
These lightweight trains were also able to run on the old (long since razed) Fulton el, which was not built to handle steel rolling stock.
As the TA wanted to retire all "non-standard" rolling stock from its roster by the 1960s, these fast and commodious trains were retired in 1961, when they still had a lor of "pep" to them...........
https://www.nycsubway.org/perl/show?75622
https://www.nycsubway.org/perl/show?132282
https://www.nycsubway.org/perl/show?46936
["7004"]
PostPosted: Fri Feb 06, 2026 9:14 am    Post subject: Reply with quote
Taking a brief "detour" from Brooklyn for a moment.......
On this day in 1941, the famed CNS&M "ELECTROLINERS" enter service, running between Chicago's Loop and Milwaukee.
After the CNS&M was abandoned in 1963, the two trains headed east, and were rehabbed for service on the Red Arrow's Norristown line (former P&W), where they operated until the 1970s (their trolley poles, of course, were not needed, as this line was 100% third rail)
Thankfully, both of these sleek and historic electric trains survive today......
["CNS&M"]
["RED ARROW LINES"]
Last edited by NEW YORK OMNIBUS 2629 on Fri Feb 06, 2026 9:22 am; edited 1 time in total
PostPosted: Fri Feb 06, 2026 9:21 am    Post subject: Reply with quote
BUDD-built electrics for the NYW&B.......
I've seen a drawing of what would have been a new generation of rolling stock for the long-defunct NYW&B(abandoned 1937)
Had the "Westchester" been able to survicve, the new rolling stock would have been built by BUDD; these two-unit articulated trains closely resembled the BMT's "Zephyr".
These trains would have also had motorman's portholes, which were found on the original 1912 MUs.
Alas,it was not to be.....
["WHITE PLAINSEXPRESS"]
PostPosted: Sat Feb 07, 2026 9:33 am    Post subject: Reply with quote
Interesting........
In New York, only the BMT ever experimented with (and operated) articulated trains; neither the IRT nor the IND ever showed any interest in the concept of articulation.
Articulation would have certainly seemed appropriate for the IRT, with its tight curves and twisting tunnels (like PATH/H&M)...........
["INTERBOROUGH"]
PostPosted: Thu Feb 12, 2026 12:45 am    Post subject: Reply with quote
Why the CA&E stopped serving The Loop..........
In 1953, the CA&E voluntarily cut back service from The Loop (Wells Street) to Forest Park; as the railway entered the Loop via the Garfield Park "L", it refused to operate into Chicago via the new ground-level line, a temporary route that was built when the old Garfield Park "L" was demolished to make way for expressway construction.
The temporary, street-level route featured numerous grade crossings (no crossing gates) and "L" trains had to come to a complete stop at a crossing before proceeding.
This, of course, translated into a ponderously slow ride, and the CA&E (not surprisingly) wanted no part of this operation.
CA&E trains now terminated at Desplaines Avenue/Forest Park, where the station was renovated to allow for transfer to "L" trains.
Within four months, the cash-strapped "Roarin' Elgin" saw half of its ridership evaporate.
Though detailed plans had been drawn up for the CTA to take over the CA&E (as far as Wheaton) and operate "L" trains into the Loop, the elaborate plans fell by the wayside...........
["CHICAGO EXPRESS"]
PostPosted: Mon Feb 16, 2026 9:43 am    Post subject: Reply with quote
Sobering..........
With thee exception of those fortunate ex-Chicago streetcars today preserved in rail museums, that virtually nothing at all remains within the city that could be associated with what was once the largest streetcar system in the world........ Sad
["CHICAGO SURFACE LINES"]
PostPosted: Tue Feb 17, 2026 10:42 pm    Post subject: Reply with quote
Interesting..........
Chicago's first subway, the State Street Subway opened in 1943, at the height of WW2.
However, in New York, the extension of the IND's Fulton line (Brooklyn) had been largely completed just before the War, but all construction of the line to Euclid Avenue was halted, and did not resume until after the War.
Service to Euclid Avenue ("A" line) finally commenced in 1948.
["INDEPENDENT SUBWAY SYSTEM"]
Page 20 of 20
