Joined: 18 Dec 2007 Posts: 22860 Location: NEW JOISEY
Posted: Thu Apr 25, 2024 11:22 pm Post subject: |
(SEE PREVIOUS POSTS)
This 2007 photo at Fresh Pond is indeed interesting, as it depicts a solo OOS RTS ("Torpedo"), between the BMT ramps.
Note the "DO NOT START" message scrawled on the windshield...............
https://www.nycsubway.org/perl/show?70201
["RTS"]
Last edited by NEW YORK OMNIBUS 2629 on Sat Apr 27, 2024 11:10 am; edited 1 time in total |
Posted: Thu Apr 25, 2024 11:31 pm Post subject: |
Here, it's 1974, and we have a train of "Museum" Lo-V's heading down the ramp at Fresh Pond; down below, the area between the ramps is now jammed with Fishbowls, silently awaiting the torch............
https://www.nycsubway.org/perl/show?8069
["INTERBOROUGH"] |
Posted: Fri Apr 26, 2024 12:38 am Post subject: |
The storing of scrap-bound buses between the BMT ramps at Fresh Pond........
From the photos I've gleaned gleaned from the nycsubway.org galleries, it would appear that this area began to be used as a "repository" for OOS buses sometime about 1970.
Through at least the mid-1970s, retired "Shermans" and Fishbowls were parked in this tight area, as they awaited scrapping.
Only one photo depicts "Dangerfields" parked between the Fresh Pond ramps.
The most recent photo to show any buses parked here dates to 2007 (the rare photo showing an RTS)
It would be interesting to find out exactly when the "Tee-Yay"/"Em-Tee-Yay" began parking retired buses here, and when this practice ended.
As can be seen in the photos whose links I've posted, at times the constricted space between the ramps was jammed with retired buses, while, at other times, only two or three were on hand............
["MTA"] |
Posted: Fri Apr 26, 2024 6:15 pm Post subject: |
Further:
The most recent photos taken at Fresh Pond (showing the former "bus repository" between the El ramps) show that the area is now virtually empty, with perhaps a van or a small truck parked there.
As noted earlier, it would seem that one (or possibly two) photos show an RTS parked at this location; if a group of retired RTS were ever stored there, prior to scrapping, I've yet to see any photos.
Too, as noted earlier, I've only come across one photo that depicts "Dangerfields" parked between the El ramps.............
["FLXIBLE"] |
Posted: Fri Apr 26, 2024 8:38 pm Post subject: |
Also, if you notice the photos taken between the BMT ramps at Fresh Pond, you will notice that the area was empty through the 40s, 590, and for much of the 1960s, with no buses to be seen.
It was not until about 1970 (going by the photos at nycsubway.org) that the MTA began to temporarily store retired buses (awaiting scrapping) at this location.
Just when this practice ended, I am not sure, but, it seems that the latest photos where a group of buses is stored between the Fresh Pond ramps is the mid-1970's............
Posted: Fri Apr 26, 2024 10:18 pm Post subject: |
In this mid-later 1970s-era scene, we see only a couple of buses dusted with snow; the rest of the area between the tracks is otherwise empty (the graffiti-covered R-16s in the background further date this photo)...........
https://www.nycsubway.org/perl/show?41792
["M"] |
Posted: Fri Apr 26, 2024 10:36 pm Post subject: |
In this photo from 1971 (which I linked previously) you can glimpsed an a/c equipped bus; I doubt if a bus this new (in 1971) was going to be scrapped, unless it had been involved in a serious accident, where the front end was damaged beyond economical repair............
https://www.nycsubway.org/perl/show?158291
["FRESH POND ROAD"] |
Posted: Fri Apr 26, 2024 11:29 pm Post subject: |
In 1970, the last ex-SURFACE TDH-5106s were retired; for some time, they were stored in the yard at the Colesium depot.
One of these distinctive buses (with the protruding front sign box) can be seen here (link below) at Fresh Pond, one year after retirement, in 1971.
I wonder if all of these forty buses were driven (or, more likely, towed) from the Colesium depot to Fresh Pond, prior to being scrapped.
FACL also rostered 50 of this type..........
https://www.nycsubway.org/perl/show?5618
["ST"] |
Posted: Sat Apr 27, 2024 12:36 am Post subject: |
Another interesting "mystery" surrounding the long-abandoned "bus repository" between the El ramps at Fresh Pond, is that virtually all photos show Old Looks (aka "Shermans") and Fishbowls parked in this area.
Only one photo shows Flex New Looks (aka "Dangerfields") resting there, and only one photo showing an RTS ("Torpedo")
As noted (and I've posted several photo links previously relating to this), while there are photos of soon-to-be-scrapped MACKS ("Pattons") at Fresh Pond, no photos show any between the El ramps, which is interesting......
["TA"] |
Posted: Sat Apr 27, 2024 11:01 am Post subject: |
Though an ancient "Lo-V" work motor dominates the foreground, note the line of Old Looks (aka "Shermans") in the background.
As these buses look to be in good shape (and are still carrying ad cards) they might have still been in service, at the time of this 1969 photo.
Recall, by 1972/1973, the MTA had purged the last of the Old Looks from the fleet.......
https://www.nycsubway.org/perl/show?150322
["MCB"] |
Posted: Sat Apr 27, 2024 11:06 am Post subject: |
The same yard, in a view dating to the 1980s.
Here we have a group of RTS awaiting their next runs, in the right background.
Note also, the ancient BRT line poles now carrying modern street lighting.....
https://www.nycsubway.org/perl/show?114907
["RTS"] |
Posted: Sat Apr 27, 2024 2:19 pm Post subject: |
I just came across this photo (had not seen this one previously) taken at the 36th Street yards (1960s)
Note the row of "Shermans" at left; these appear to be buses still in revenue service, and ready for duty............
https://www.nycsubway.org/perl/show?41842
["New York City Transit Authority"] |
Posted: Sat Apr 27, 2024 11:05 pm Post subject: |
Further comparison of station tablet tiles ("BROAD STREET" [BMT]/"WYOMING"[BSS])...............
https://www.nycsubway.org/perl/show?98426
https://www.nycsubway.org/perl/show?143879
I think it is also important to remember that, when the first section of the BSS opened in 1928 (outside of Boston), New York was the only other city to have a "SUBWAY".
So, it would stand to reason, that the tilework used in the BSS's stations would indeed emulate New York
["SUBWAY"] |
