PSNJ: the last years........
Goto page Previous  1, 2, 3 ... 14, 15, 16
PostPosted: Wed May 10, 2023 4:43 pm    Post subject: Reply with quote
When PS decided to replace the ASV's with diesel buses; the first lines to be converted were those serving the HUDSON Division, in 1947.
The remaining ESSEX Division lines were converted during 1948.
Initially, the ASV's were replaced by new TD-4008's; soon to follow were the 4509's, which PS purchased in great numbers........
(Source: "PUBLIC SERVICE OF NEW JERSEY'S ALL-SERVICE VEHICLE" (Wilkins/Phraner)
["27 MT. PROSPECT"]
PostPosted: Wed May 10, 2023 10:48 pm    Post subject: Reply with quote
........at one time, (beginning in the mid/late 1930's) PS also operated single-door, rear-engine YELLOW gas buses (similar to the ASV Model 729's) for intercity service.
These buses were also equipped with roof-mounted luggage racks.
Between 1948 and 1950, PS also acquired a number of GM PDA-4101's (these buses were numbered in the "B" series).......
["ATLANTIC CITY"]
PostPosted: Thu May 11, 2023 12:17 pm    Post subject: Reply with quote
Historical footnotes:
In 1948, Public Service Electric & Gas was formed, as per requirements of the SEC, with PSCT remaining as a wholly-owned subsidiary.
In 1971, PSCT becomes TRANSPORT OF NEW JERSEY (TNJ), as the parent firm attempts to distance itself from the money-losing public transport business. The parent firm is now traded as Public Service Enterprise group.
In 1976, the NJDOT, on behalf of TNJ and other bus operators, orders 866 New Look buses from FLXIBLE; this was New Jersey's largest bus order up to that date.....
'NYO"
["166 NEW YORK"]
PostPosted: Thu May 11, 2023 7:22 pm    Post subject: Reply with quote
ASV's.............
Until I purchased the outstanding book "PUBLIC SERVICE OF NEW JERSEY'S ALL-SERVICE VEHICLE" (Wikins/Phraner) I had no idea whatsoever just how complicated a vehicle the ASV was, nor did I have even the slightest clue as to how involved it was for a driver to pilot.
The dashboard was very advanced for the day, and far more complex that which would have been found on any of the gas buses of the day.
In addition to a brake pedal, there were also two accelerators, one for use in trolley bus mode, and one for use in gas mode.
There were also buttons for automatically raising and lowering the trolley poles.
PS men went through a very involved and intricate training period, prior to getting behind the wheel of an ASV for the first time......
["49 UNION"]
PostPosted: Fri May 12, 2023 2:16 am    Post subject: Reply with quote
Another very interesting aspect of ASV operations were the reversal loops at each end of the line.
Some lines utilized a "wired"loop, allowing the coach to anter and leave the loop via electric power.
Other lines used "non-wired" loops, meaning that the driver (at the end of a certain line) would have to lower the poles and switch over to gas power, use a non-wired loop, and then head back to the wire pan, where the driver would automatically raise the poles.
At 90th Street & Bergenline Avenue (North Bergen) ASV's of the "#21" out of Hoboken (these were the runs that either "short-turned" near Nungessers, or ran through to Palisades Junction, in Fort Lee); would stop, with the driver acknowledging the metal sign that hung from the cross-span wires "EOW"("End Of Wire").
The poles would be lowered and the bus, if on a thru run to Fort Lee, would simply continue its run in gas mode.
If, however, the run was a "short turn", the driver (with poles locked down) would swing west on Hudson Boulevard for a block, before turning into a side street, and then another, to get back onto Bergenline Avenue for its inbound run to Hoboken.
The driver would position the bus underneath the wire pan, and (after switching to electric mode) raise the poles; the pan would automatically guide the poles onto the overhead.....
["21 WEST NEW YORK"]
PostPosted: Fri May 12, 2023 10:16 am    Post subject: Reply with quote
Had the "D900" ASV revival gone through, it would not have been a monumental tremendous expenditure, regarding the new overhead wiring.
Though new wire would have been erected in the City Subway, it would not have gone beyond this, as the new diesel-electric coaches would have only used overhead while using the Subway.
Several factors, as I had mentioned previously, led to PSNJ abandoning the ASV revival, but, the factor that was "the deciding vote" was that the City of Newark refused to foot the bill for the paving over of the Subway ROW.
PS decided it was indeed far cheaper to purchase second-hand streetcars for the "#7 CITY SUBWAY"; the last of the connecting subway-surface streetcar lines (#29) was converted to diesel buses in March, 1952.
PS eventually purchased thirty used PCC cars from TCRT, beginning in 1953; these venerable cars, indeed iconic, ran until replaced by new light rail units in 2001.
Had the ASV comeback gone through, PS would have purchased nearly 100 of the "D900"-type GM-built ASV's, for routes entering downtown Newark via the subway......
["7 CITY SUBWAY"]
PostPosted: Wed Jul 19, 2023 6:03 pm    Post subject: Reply with quote
.........I've just learned of the demolition of the historic, sprawling ex-PSNJ carbarn/garage in Union City, between 27th St. and 29th Streets, and Bergenline and New York Avenues.
The oldest part of the building (with castle-like turrets, and dubbed "The Big House" by PS men) was built during the 1890's; the newer section of the building was built over an open streetcar storage yard, prior to WW1, bordering on 29th St.
I grew up with this historic facility; I have so many memories.
NJT closed the facility in the early 1990's (several bays still had the long-dormant streetcar tracks embedded in the floor; the last streetcars departed in August, 1949)
Oddly, the ex-PSNJ Market Street garage in Paterson, designed very much like the Union City facility, is being renovated by NJT, and is also a landmark.
Interestingly, NJT will be building a new garage/support facilities/office space on the Union City site, and will also handle electric buses.
A terminal will also be incorporated into the new facility.
I find it quite ironic that, after NJT closed the Union City garage some three decades ago, they are now returning to the same location, albeit with a new garage/office/terminal complex
Today, the only ex-PS carbarn/garage in Hudson County still standing is the former West New York carbarn/garage; it has been used as a DPW facility for decades, and had changed very little over the decades.
Another historic piece of PS's rich legacy has, sadly, vanished down the echoing corridors of time.......... Sad
["UNION CITY"]
Last edited by NEW YORK OMNIBUS 2629 on Thu Jul 20, 2023 12:50 am; edited 1 time in total
PostPosted: Wed Jul 19, 2023 11:00 pm    Post subject: Reply with quote
These two photos (the first dating to the mid-1930's, and the second to the 1940's) were taken just outside of PSNJ's Union City car house/garage (this is the eastern side of the facility,on New York Avenue)
Car #2135 (painted in the "De Luxe" scheme, and converted to one-man, single-end operation) is signed for the "SUMMIT" line.
This line, and the "UNION CITY" line were the last two Union City streetcar lines when they were converted to buses in August, 1949.
"Compromise" roof-car #3281 (seen sporting the last new PS paint scheme for the trolleys) is on an NRHS excursion; the car is signed for "OAKLAND", which was a Jersey City route, based out of the (since demolished) Greenville carhouse, which also served ASV's and buses.
The apartment houses on New York Avenue still survive today.
Vestiges of some of the old trolley rails were visible for many decades after the streetcars stopped running.................
https://www.nycsubway.org/perl/show?118312
https://www.nycsubway.org/perl/show?117015
["SUMMIT"]
Last edited by NEW YORK OMNIBUS 2629 on Wed Jul 19, 2023 11:12 pm; edited 1 time in total
PostPosted: Wed Jul 19, 2023 11:07 pm    Post subject: Reply with quote
These work cars were spotted on the New York Avenue side of the Union City carbarns; the diminutive rail grinder (which originally was assigned to the CENTRAL Division's "43 UNION" until that line was converted to ASV in 1935) was later sold to CAPITAL TRANSIT (Washington)
The snow sweeper is marked "BIG TREE"; this PS facility on the CENTRAL Division went to bus/ASV in 1937, and this car was then transferred to the HUDSON Division for further service.........
https://www.nycsubway.org/perl/show?117971
https://www.nycsubway.org/perl/show?117972
https://www.nycsubway.org/perl/show?117966 *
*The PS bus in the background is facing east on 29th St.
(courtesy:nycsubway.org)
["PSNJ"]
PostPosted: Mon Jul 24, 2023 7:46 pm    Post subject: Reply with quote
Interesting PSNJ (Union City) trivia.........
Though ASV's operated on the HUDSON Division through 1947, the UNION CITY garage/carbarn was the only PS facility on the HUDSON Division not to serve as a base for the dual-powered trolleybuses.
The HUDSON Division ASV's were stabled/repaired at the WEST NEW YORK garage (last streetcars in 1938), and, also at GREENVILLE (Jersey City)
Like UNION CITY, the last streetcars departed from this facility in August of 1949.
The heaviest repairs for ASV's/buses/streetcars were carried out at the PLANK ROAD shops in Newark...........
Page 16 of 16
