.....and leave the driving to us......
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 71, 72, 73  Next
Post new topic   Reply to topic    BusTalk Forum Index -> Over The Road Carriers
PostPosted: Sun May 10, 2020 4:43 pm    Post subject: Reply with quote
One of my "fun activities" was putting together some thru bus schedules, to link far off places, but using combinations of different routes that did not actually have such thru services. Other things were to run the fastest possible schedule from coast to coast, by using the current fastest running times between the fewest and longest segments currently used....
Or...try to go as far a distance as possible, using only independent carrier's, and not using Greyhound or Trailways....
Hours of diversion, if you have a Russell's Guide... Cool
I used to do much the same, EXCEPT, that I would also lay out a flat world map, and, using different colored pencils, create a world-wide high-speed, inter-continental rail network, linking ALL continents!
In one such arrangement, I had direct service from New York to S. Africa, via London, Paris, and Rome, with "express" service also available! Shocked
New York to Australia and Japan also were "penciled in"......... Wink
PostPosted: Sun May 10, 2020 4:50 pm    Post subject: Reply with quote
This should be of interest........
http://www.esva.net/~rwest/ferries.html
PostPosted: Sun May 10, 2020 4:56 pm    Post subject: Reply with quote
See also:
https://en.wikipedia.org/wiki/Cape_May-Lewes_Ferry
PostPosted: Sun May 10, 2020 10:31 pm    Post subject: Reply with quote
........autos (and buses!) carried for free on these ferries...... Wink
https://en.wikipedia.org/wiki/Jamestown_Ferry
PostPosted: Mon May 11, 2020 9:02 am    Post subject: Reply with quote
How about this one, for history...incredible!
And...you can still ride her today.... Cool
https://en.wikipedia.org/wiki/USS_LST-510
https://www.longislandferry.com/Common/Help.aspx?page=fleet
PostPosted: Mon May 11, 2020 9:23 am    Post subject: Reply with quote
WOW!!!! Shocked Shocked
THANKS for posting these links! Wink
MOST refreshing, indeed, to see historic vessels such as this IN SERVICE, and not being either scuttled or allowed to decay at pierside for decades! Very Happy
PostPosted: Fri May 29, 2020 11:17 pm    Post subject: Reply with quote
I always wondered, from my much younger days, why TRAILWAYS had a storefront depot on 32nd Street in Union City (my hometown, from 1957 until 1971), but not in Journal Square (Personally, I cannot recall a TRAILWAYS depot at Journal Square)
However, GREYHOUND had a depot on Sip Avenue in Jersey City well into the 1970's, but no depot in Union City........
PostPosted: Fri May 29, 2020 11:25 pm    Post subject: Reply with quote
Quite awhile back (in another topic on this board) I can recall inquiring just where GREYHOUND had its facilities for bus repair/storage/driver accomodations, etc. in Manhattan (I believe this was on the West Side)
Where did TRAILWAYS have similar facilities? (somewhere in the vicinity of the PABT?)
With TRAILWAYS long gone, and GREYHOUND basically on life support, I would imagine that whatever GREYHOUND facilities are in Manhattan today (do they even exist?) must be quite "scaled down" from what they were, 50-60 years ago......
PostPosted: Sat May 30, 2020 10:37 am    Post subject: Reply with quote
I think the main reason was that only "locals" would spend the time it took going via Journal Square, such as on a Philly Local via Route 1 or 130, while making the quick stop in Union City took only a couple of extra minutes on a "Turnpike Express"....
PostPosted: Sat May 30, 2020 10:54 am    Post subject: Reply with quote
Back in the late '60's, when I worked for Safeway Trails...we had a garage at the west end of the block between 40th and 41st street, along 11th Avenue.
Directly across the street where GL built their enormous block long garage (now MTA's Quill Depot). The site was last occupied by the Manhattan Mercedes Benz dealership. Our garage had 2 inside, and one outside service lanes, a small repair area, and parking outside for about 40 or so buses. On the upper level was a large driver's lounge with a dozen recliner's and a tv and vending area. Along with parts and other storage space.
In addition, with our merger into Continental Trailways, we also used the American Buslines garage in Hoboken, which had 9 pits, two inside and one outside service lanes, parts rooms, office space, room to park outside about 60 or so buses. This space was later purchased by The Berardi Family, owners of Adirondack and Pine Hill Trailways. They leased it for 30 years to Gray Line of NY, and then paid them to service and store ADT buses.
Adirondack did have its own Manhattan garage on 37th street between 10th and 11th, which is currently owned by Verizon Communications.
Prior to Greyhound building its mammoth NY Maintenance Center in 1968, it operated out of two much smaller facilites. One was on 43rd street, I believe where UPS is now, the other in Long Island City, under the Queensboro Bridge ramps. Greyhound did have facilites on MTA property adjacent to the LIRR West Side Yard, and a lot across 30th Street from it.
They left that for several years, and used Academy's lot in Hoboken, but more recently moved back into the 30th street lot, along with a PA owned lot on Dyre Avenue between 40th and 41st Streets, under the upper level ramps. Not sure of what is currently being used, since the big shutdown of schedules due to the pandemic...
PostPosted: Sat May 30, 2020 11:19 am    Post subject: Reply with quote
Many thanks for taking the time to post this great "in depth" historical info....MOST interesting! Wink
You were indeed fortunate to actually "live those days" on a "first hand" basis; I am sure, when you think back today, you realize how much the "over the road" bus industry has changed in the past 50-odd years.
I well recall the lots in Hoboken; I can remember seeing ACADEMY buses and also GRAY LINE vehicles; a few times, before I retired, I remember seeing GL double-deck tour buses heading for the Lincoln Tunnel.
Indeed, I can imagine the impact that the "long-haul" carriers have felt, during the pandemic; I remember reading, weeks ago, of MARTZ shutting down; also, LAKELAND (I believe that LAKELAND has since instituted limited service, with restrictions)
Years ago, there was a site, (I believe was called "Don's Greyhound Bus Memories", or something like that); the issue with that exhaustive site (along with its companion site on TRAILWAYS) was that the photos were in "angelfire" format, which often caused issues with viewers (I was lucky; I never had any issues with the photos, and there were TONS of rare old views, of both buses and stations!)
I also remember there were some really neat 1930's-era photos of the GREYHOUND facility in Long Island City, showing front-engine buses and 743's.........
PostPosted: Sat May 30, 2020 12:11 pm    Post subject: Reply with quote
Talk about the Long Island City facility...I remember towards the end, just prior to the new garage opening in '68...how the driver's loathed having to take a Scenicruiser over there. I believe their contract only gave them an incredible flat 75 cents for that, at the time. They received a decent 15 cents per mile wage on schedule trips then. Which was equivalent to about 9 dollars per hour...not bad for 1967.
Driver's would do almost anything to get out of taking that drive in heavy crosstown and bridge traffic, which could take anywhere from a half hour to two hours.
Needless to say, they were so happy to see that end... Smile
PostPosted: Sat May 30, 2020 12:23 pm    Post subject: Reply with quote
My first job, after leaving high school, was as an office boy (general clerical help), for Greyhound Leasing and Financial Corporation, in 1966, for a couple of months, prior to enlisting in the USAF. I spent spare time poring over the Annual Reports to Stockholder's of the Greyhound Corporation, which had acquired Boothe Leasing, in 1962, the actual subsidiary I worked for. This further enhanced my interest in buses, and I had applied to them, mistakenly thinking it was a 'pipeline' to employment at Greyhound Lines. But I could say that I worked for the same parent organization.
The reason I mentioned that, was because it was located in the office building at 445 Park Avenue, right off 57th Street. Lunchtime, would find me walking along 57th, where I had a fair chance of spotting a Scenicruiser enroute to or from the LIC garage. They were looking good since their recent rebuilding into "Super Scenicruiser's", with their gold Scotchlite stripes gleaming in the sunlight.
PostPosted: Sat May 30, 2020 1:15 pm    Post subject: Reply with quote
Might I suggest you publish an autobiography, and entitle it:
"TRAILS OF A TRAILDRIVER" Wink
I'll tell you this; I will be FIRST in line at the book signing! Very Happy
(just make sure you include a LOT of photos!) Wink
It's truly sad that most of the "old hands" (regarding veteran SCENICRUISER drivers, mechanics, etc.) have now since passed on to that big garage in the sky; the experiences they had on the road, the stories they could tell, sadly, for the most part, have also vanished with them. Sad
Something else I've been curious about for quite awhile; back in the day, were there more SCENICRUISERS to be seen in the New York lots, or 4104's/4106's, or, roughly about 50/50?
In "AMERICAN BUSES" (David Jacobs, 1985) there is a photo showing the interior of the TRAILWAYS offices at 625 8th Avenue in Manhattan (there's a NICE model Eagle in this photo as well!) Very Happy
The photos (NICE!) included two buses (a PREVOST and an EAGLE) lettered "SCENIC TRAILS", which was "under the corporate blanket of the TRAILWAYS organization".
Said company ran charters and tours (La Crosse, WI)
Hard to believe that the photos in this book are now at least 35 years old.....how much has changed.....and vanished, since then.......
PostPosted: Sat May 30, 2020 10:57 pm    Post subject: Reply with quote
Greyhound drivers of the "Olden Days".........
While watching the 1934 classic comedy earlier, "IT HAPPENED ONE NIGHT", and seeing "Hound" drivers in military-style uniforms, got me to thinking of how TOUGH these fellows had to be, to drive a highway coach back in the 1930's.
Manual transmissions, no power steering, no air-conditioning, no super-highways, expressways, freeways, or multi-lane turnpikes.....these drivers had to truly "ROUGH IT"!!!!! Shocked
I'm willing to wager that these early "Hound" drivers indeed got one heckuva workout, every time they piloted their brutish buses from point "A" to "B"! (no need to head to one of the "old school" gyms of that era!) Rolling Eyes
Too, think of all the rest stops/meal stops en route, at little roadside stands and other local establishments; in 1929, the era of the true "modern" GREYHOUND terminal began when the new San Antonio station opened, featuring a novel mezzanine where baggage men loaded luggage directly to the rooftop luggage racks of waiting buses.
Too, think of the times if a bus became disabled (or otherwise stranded) in a more rural area; how far would a driver have to walk to find a telephone to call for assistance?
Yup, without a doubt, the resilient "Hound" drivers of that era were indeed "IRON MEN", in every sense of the word.
Back in the 1960's, surely, there were still older drivers who could still recall the days of front-engine buses, humble roadside stands, and military-style uniforms, which they clearly were proud of......
Post new topic   Reply to topic    BusTalk Forum Index -> Over The Road Carriers All times are GMT - 5 Hours
Page 8 of 73
