Joined: 26 Mar 2011 Posts: 2751 Location: South Florida
Posted: Fri Nov 30, 2018 12:53 pm Post subject: |
Since heavy truck and bus transmission's have too much torque to use the "synchromesh" synchroniser's that manual automobile transmission's do, the "constant mesh" transmission's require double clutching and proper RPM matching to avoid clashing or grinding gears. When downshifting, the driver must 'blip' the throttle while in neutral, to raise the rpms, while in neutral to the proper speed to select the lower gear. It is an 'art' that takes some practice, but once mastered, is a very satisfying skill to possess...
One thing that is actually easier to do with a constant mesh tranny than a synchro, is to change gears without even using the clutch...that's a real skill...
Age: 72 Joined: 27 Feb 2013 Posts: 1236
Posted: Sat Dec 01, 2018 7:09 pm Post subject: |
Here is the cover for the sales brochure of the "Golden Chariot", model PD-4901.
As well as the specifications and seating diagram
181.31 KB |
69318 Time(s) |
161 KB |
69318 Time(s) |
204.79 KB |
69318 Time(s) |
Posted: Sat Dec 01, 2018 9:40 pm Post subject: |
Nice brochure, thanks for posting it...
Its specs were just about identical in many areas to the PD-4501 Scenicruiser, except IIRC, the Scenic was 132" tall...an inch and a half taller?
TheDriver
Posted: Sun Dec 09, 2018 12:04 pm Post subject: |
| and 4 more seats.
Posted: Mon Dec 10, 2018 12:27 am Post subject: |
| That's true...with its single deck design, it was a lot easier to squeeze in an extra row. Greyhound did that near the end of the Scenicruiser's life, to use on several California commuter runs.
Steve Carras
Age: 65 Joined: 05 Mar 2010 Posts: 63
Posted: Tue Dec 11, 2018 8:19 pm Post subject: |
| Thanks for the picture,
