Canadian New Look GMC's in New York
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Mon Aug 14, 2017 10:48 pm    Post subject: Reply with quote
A more subtle "variation" in the GM New Looks over the years is that on some buses the "GM" letters were absent on the trapezoid; on some buses, even the trapezoid might be removed.
This was something that always puzzled me; I always wondered in GM might have cast a disgruntled eye on this removal........
Last edited by NEW YORK OMNIBUS 2629 on Mon Aug 14, 2017 11:28 pm; edited 2 times in total
PostPosted: Mon Aug 14, 2017 11:11 pm    Post subject: Reply with quote
Note the New Look to the rear in this 1972 view; no GM trapezoid on the dash, nor an advertising mounting........
http://bus.nycsubway.org/perl/show?2576
PostPosted: Mon Aug 14, 2017 11:16 pm    Post subject: Reply with quote
Circle Line pier, 1976........
http://bus.nycsubway.org/perl/show?1202
GBL Rebel
PostPosted: Tue Aug 15, 2017 9:53 am    Post subject: Reply with quote
MTA NYCT tends to order buses minus any manufacturer badge.
PostPosted: Tue Aug 15, 2017 6:13 pm    Post subject: Reply with quote
That's because you have a blank advertising board blocking the trapezoid. If you look closely, you can see where the board cuts the extreme right side of the headlight bezel.
PostPosted: Tue Aug 15, 2017 9:34 pm    Post subject: Reply with quote
You are right.......appreciate the heads up! Wink
I had to really look close, but I did see just what you saw; I could not see that I was looking at a blank advertising panel, only what looked like a bare dash........
PostPosted: Tue Aug 15, 2017 9:36 pm    Post subject: Reply with quote
GBL Rebel:
Appreciate your input; to be honest, I never really looked at the builder's badges on any NYC buses since the long-gone days when the GRUMMANS were running side-by-side with the New Looks.........
GBL Rebel
PostPosted: Wed Aug 16, 2017 9:33 am    Post subject: Reply with quote
If it wasn't for Suffolk County buses, I wouldn't know what the last Orion emblem looked like. Keep in mind I work with Orion's daily.
PostPosted: Wed Aug 16, 2017 7:03 pm    Post subject: Reply with quote
GBL Rebel:
In reality, all GM new looks came with builder's badges and it was up to the transit companies to remove them as they seemed fit.
Today, most builders have their name either embossed or debossed into the bus panel itself - almost indistinguishable since they're the same color as the panel.
PostPosted: Thu Aug 17, 2017 12:03 am    Post subject: Reply with quote
GBL Rebel:
In reality, all GM New Looks came with builder's badges and it was up to the transit companies to remove them as they seemed fit.
I did not know this......appreciate your sharing here. Wink
To this day, I truly believe that the New Look "GM" trapezoid is still an easily recognizeable trademark, not only in the transit sector, but also in American Industrial History.
The New Looks were buses that indeed were timeless in design; they looked every bit at home in the 1980's and 1990's as they did in the 1960's and 1970's......I'll never stop missing them....but sure am glad I rode them as much as I did....... Very Happy
PostPosted: Thu Aug 17, 2017 8:32 am    Post subject: Reply with quote
Is the confusion on that the reason why, on such front ad racks, the 'M' sticker was put on them later in the '70's after the buses were repainted in two-tone blue?
Page 5 of 5
