GBL Rebel Moderator
Joined: 16 Apr 2007 Posts: 608 Location: Long Island, N.Y.
Posted: Sun May 25, 2014 7:11 pm Post subject: |
R62CNG wrote: | GBL Rebel wrote: | NorthShore wrote: | MTA Bus retired Queens Surface last RTS's prematurely (8 years old). I do not know why. |
These would have 1994 TMC RTS's. MTA Bus took over QSC in February 2005 and renumbered them 9700's. These buses were sent to other MTABC garages. Hybrids came in 2007 which made the final push of older equipment. They actually lasted 12 years. | The Orion VIIs stated to arrive towards the end of 2005. |
No way 3500 came in the end of 2005. Tell you what, I will have the builders plate checked for date of manufacture on the lowest 3500 I can get my hands on.
Furthermore, the comment I answered was "MTA Bus retired" which still would have made the newest QSC TMC RTS 11 years old at the time of takeover. And with all the moves that happened, it would be easy to lose track.
Next time read the whole thing before you post "Wrong". Thank you for your cooperation. |
R62CNG Banned
Posted: Sun May 25, 2014 7:24 pm Post subject: |
Back in the year 2005, the 1994 TMC RTS's would indeed be 11 years old. I never said otherwise. |
GBL Rebel Moderator
Posted: Fri Jun 06, 2014 4:59 pm Post subject: |
R62CNG wrote: | The Orion VIIs started to arrive towards the end of 2005. |
3501 Date Of Manufacture - August 2006 |
R62CNG Banned
Posted: Sun Jun 08, 2014 11:25 pm Post subject: |
GBL Rebel wrote: | R62CNG wrote: | The Orion VIIs started to arrive towards the end of 2005. |
3501 Date Of Manufacture - August 2006 | What about bus #3500? |
GBL Rebel Moderator
Posted: Mon Jun 09, 2014 9:30 am Post subject: |
Off the property. When it comes back I will check. There were no demonstration buses as NYCT already had them. So 3500 may be a bit earlier but no way is it 2005.
Actually, I will check in service date of both. Problem solved. |
Posted: Mon Jun 09, 2014 12:19 pm Post subject: |
FWIW, 3500-3524 were manufactured between 6714 and 6715. |
GBL Rebel Moderator
Posted: Tue Jun 10, 2014 4:44 am Post subject: |
GBL Rebel wrote: | Actually, I will check in service date of both. Problem solved. |
3500 went in service only days before 3501. Brings us back to August 2006 unless somebody put tires on a pile of metal and used it as a bus. |
