Finally Found The Answer to CT. Blue Lights!
PostPosted: Sat Apr 05, 2014 10:44 pm    Post subject: Finally Found The Answer to CT. Blue Lights! Reply with quote
Found it in the CT PUC regulations from 1948.
Buses may use purple lights to designate intrastate service and green lights to indicate interstate service.
Rule 57 on page 14.
http://www.ct.gov/dot/lib/dot/documents/dptransportation/motorbusregs.pdf
PostPosted: Sun Apr 06, 2014 11:39 am    Post subject: Reply with quote
Thank you for spending your time to do the research. Amazing that rules published 62 years ago can be found
