S-60 To Smith Haven Mall
Joined: 29 Nov 2007 Posts: 1757 Location: Suffolk County, NY
Posted: Sun Mar 18, 2012 11:03 pm Post subject: |
As of 3/18/12
*Some buses may not fit the word Vintage due to their age, let me know if they should be removed from the list, also I believe a age should be selected to designate a bus as vintage*
(Active Bus Companies on top, Disbanded Companies on bottom)
Inter County Motor Coach
1958 GM PD-4104: 120 (Sent to Lincoln Transit NJ)
1958 GM PD-4104: xxxx
1972 GM P8M-4905A: 290
1973 GM P8M-4905A: 434
1974 GM P8M-4905A: 330-332 (#330-331 came two buses before #332)
1975 GM P8M-4905A: 1776
1975 GM P8M-4905A: 1776B
1976 GM P8M-4905A: 446
1977 GM P8M-4905A: 445-444
1979 MCI-9: 602 (Sent to Oak Tree Bus Service as #77)
xxxx MCI-9: 607
19xx -------: 615
Hampton Jitney
19xx Eagle Model xx: 30
1993 Prevost H3-41: 47
1994 Prevost H3-41: 50-51,55-56
19xx Prevost H3-45: 63
1997 Prevost LeMirage XL: 92 (Ex Sunrise Coach)
1998 Prevost LeMirage XL: 93-94 (Ex Sunrise Coach)
1999 Prevost LeMirage XL: 95 (Ex-Sunrise Coach)
2000 Prevost H3-45: 96-97 (Ex Sunrise Coach)
2001 Prevost LeMirage XL II: 98-99 (Ex Sunrise Coach)
2002 GCA Freightliner: 100 (Ex Sunrise Coach)
2002 Prevost LeMirage XL II: 101 (Ex Sunrise Coach)
2003 Prevost LeMirage XL II: 102 (Ex Sunrise Coach)
2004 Prevost LeMirage XL II: 103 (Ex Sunrise Coach)
2004 Prevost H3-45: 104 (Ex Sunrise Coach, is in a Gold Paint Scheme)
2005 Prevost H3-45: 105 (Ex Sunrise Coach)
2006 Prevost LeMirage XL II: 106 (Ex Sunrise Coach)
xxxx MCI F3500: 88
xxxx Prevost LeMirage XL-II: 90
xxxx Prevost Model X3-45 #80,84,86,89,91,98-99,101-103,106-107,112,117-119,121-122 (#91,112,117-118, and 121-122 are in the Ambassador Scheme, #113 has a side destination sign similar to MTA NYCT's Prevosts)
xxxx Prevost Model H3-45 #60,62-65,66-67,70-79,81,85,87,90,96-97,104-105,108,110-111,114-115,120,123-124 (#74 and #76 are wrapped
Sunrise Coaches Inc.
1954 GM PD-4104: 45 (Ex Monumental Tours of Baltimore, MD. Unknown number when run at Monumental Tours)
1964 GM PD-4106: 103
1981 Prevost LM-103: 300-301 (Both came in May of 1981?, but #300 was built before #301)
1997 Prevost LeMirage XL: 329 (Went to Hampton Jitney # 92)
1998 Prevost LeMirage XL: 331-332 (Went to Hampton Jitney # 93-94)
1999 Prevost LeMirage XL: 334 (Went to Hampton Jitney # 95)
2000 Prevost H3-45: 336-337 (Went to Hampton Jitney # 96-97)
2001 Prevost LeMirage XL II: 338-339 (Went to Hampton Jitney # 98-99)
2002 GCA Freightliner: 403 (Went to Hampton Jitney # 100)
2002 Prevost LeMirage XL II: 340 (Went to Hampton Jitney # 101)
2003 Prevost LeMirage XL II: 341 (Went to Hampton Jitney # 102)
2004 Prevost LeMirage XL II: 342 (Went to Hampton Jitney # 103)
2004 Prevost H3-45: 343 (Went to Hampton Jitney # 104, it once had a Gold paint scheme with Blue Lettering)
2005 Prevost H3-45: 344 (Went to Hampton Jitney # 105)
2006 Prevost LeMirage XL II: 345 (Went to Hampton Jitney # 106)
In Active Bus Companies
Coram Bus Service
1974 GM P8M-4905A: 118
1975 GM P8M-4905A: 125
1976 GM P8M-4905A: 127
1977 GM P8M-4905A: 128
xxxx MCI-9 : xxx
Harran Transportation
xxxx MCI-5C: ????
1974 P8M-4905A: 504-505
1979 MCI-9: 511-512
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, 515 went to Private Transportation)
1981 MCI-9: 519,553,565 (#565 is now a bus for a church in Wyananch)
1982 Eagel Model 10: 536
1983 MCI-9: 569
1989 Eagle Model 15: 600-605
xxxx Eagle Model xx: 523
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815
xxxx Prevost xx-xx: xxx (Space Shuttle Paint scheme)
Last edited by S-60 To Smith Haven Mall on Mon Mar 19, 2012 7:58 am; edited 1 time in total |
The TransitMan
Age: 45 Joined: 14 Oct 2010 Posts: 240 Location: Long Island, NY
Posted: Mon Mar 19, 2012 12:50 am Post subject: |
108 is an H3...not an X3.
Also, there was no X3-90. I believe that was an error on my part. |
The TransitMan
Posted: Mon Mar 19, 2012 12:56 am Post subject: |
Um...ok. Whatever you did...these are not my words.
#113 is NOT in the Ambassador scheme. Also, it's the SIDE destination sign that looks like the MTA-NYCT Prevosts. (That's my error as I look at my previous post).
Finally, #74 and #76 are wrapped. Unless if YOU saw it, #75 is not wrapped BUT I will look out for it. |
Posted: Mon Mar 19, 2012 7:56 am Post subject: |
The TransitMan wrote: | Um...ok. Whatever you did...these are not my words.
Typos on my part.
I'll also make the other changes to the above post. |
Posted: Wed Aug 22, 2012 9:21 pm Post subject: |
As of 8/22/12
Hampton Jitney
xxxx MCI F3500: 88
197x GM P8M-4905A: 334
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
xxxx Prevost xx-xx: xxx (Space Shuttle Paint scheme) |
Posted: Sat Aug 25, 2012 11:38 am Post subject: |
As of 8/25/12
Hampton Jitney
xxxx MCI F3500: 88
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
xxxx Prevost xx-xx: 2001 (Space Shuttle Paint scheme) |
Posted: Sun Sep 02, 2012 12:51 pm Post subject: |
As of 8/25/12
Hampton Jitney
xxxx MCI F3500: 88
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
xxxx Prevost xx-xx: 2001 (Space Shuttle Paint scheme, Now As of [color=red]8/25/12
Hampton Jitney
xxxx MCI F3500: 88
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815 (A few of this model went to Worldwide Tours # 745-747)
xxxx Prevost xx-xx: 2001 (Space Shuttle Paint scheme, Now Go Buses #9138 without Space Shuttle Paint Scheme) |
PreferPrevost12
Age: 34 Joined: 18 Aug 2012 Posts: 6 Location: queens, ny
Posted: Sun Sep 02, 2012 9:07 pm Post subject: |
Harran #2001 stats are 2001 prevost h3-45 if u wanna update that above |
Posted: Sun Sep 02, 2012 11:17 pm Post subject: |
As of 9/4/12
Thanks to PreferPrevost12 and tinytim for the update
Hampton Jitney
xxxx MCI F3500: 88
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815,819 (#819 Ex-Worldwide #745, Current Go Buses #9148)
2001 Prevost H3-15: 2001 (Space Shuttle Paint scheme, Now Go Buses #9138 without Space Shuttle Paint Scheme)
Clausen Bus Service (Clausen Airport Bus, Inc. Formerly N.F Bus Service
19xx GMC 4905: 111-114,119,120,124-127 (#114 Ex aventours, #124 Ex lesurie line)
19xx MCI MC-9: 121-123 (#123 went to Trombleys Bus in Mass, #121 was 53 Passengers, #122-123 were 49 Pass)
19xx MCI 96A2: 128-130 (Went to Transportation)
19xx MCI 96A2: 131-133 (Had Bee-Line written on front, went to Harran Transportation) |
Posted: Wed Sep 05, 2012 1:40 pm Post subject: |
As of 9/5/12
Hampton Jitney
xxxx MCI F3500: 88
xxxx Prevost Model H3-45 #60,62-65,66-67,70-79,81,85,87,90,96-97,104-105,108,110-111,114-115,120,123-124 (#74 and #76 are wrapped)
xxxx Prevost H5-60: xxx
1970 GMC PD-4905: 107-108
1958 GMC PD-4104: 120 (Sent to Lincoln Transit NJ)
1958 GMC PD-4104: xxxx
197x GMC P8M-4905A: 334
1972 GMC P8M-4905A: 290
1973 GMC P8M-4905A: 294
1973 GMC P8M-4905A: 434
1974 GMC P8M-4905A: 330-332 (#330-331 came two buses before #332)
1975 GMC P8M-4905A: 1776
1975 GCM P8M-4905A: 1776B
1976 GMC P8M-4905A: 446
1977 GMC P8M-4905A: 445-444
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1974 GMC P8M-4905A: 504-505
1976 GMC P8M-4905A: 506-507
1977 GMC P8M-4905A: 508,
1979 MCI-9: 511-512
1979 GMC H8H-649: 514
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, . 515 went to Private Transportation)
1983 MCI-9: 569
xxxx MCI 96A2: 607
Long Island Airports Limousine Service
1976 GMC P8M-4905A: #703
Last edited by S-60 To Smith Haven Mall on Wed Oct 30, 2013 11:44 am; edited 4 times in total |
Joined: 26 Mar 2011 Posts: 2459 Location: South Florida
Posted: Thu Sep 06, 2012 11:20 pm Post subject: |
Didn't Hampton Jitney have some of those Prevost H5-60 articulated coaches?
Edti: Oh, I see the last update does include that model..... |
Posted: Fri Sep 07, 2012 12:39 pm Post subject: |
As of 9/7/12
Hampton Jitney
xxxx MCI F3500: 88
Hampton Express, Inc/North Fork Express
1988 MCI 102A2: 13
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569, 573 (#573 went to Charter Bus Lines of British Columbia #204)
xxxx MCI 96A2: 607
1976 GMC P8M-4905A: #703 |
Posted: Mon Dec 24, 2012 1:02 pm Post subject: |
Here is Coram Bus Service 1976 GM P8M-4905A #127, at Philadelphia end of Ben Franklin Bridge. Its said that the photo was taken July 1st 1978.
Posted: Tue Apr 02, 2013 8:51 pm Post subject: |
As of 4/2/13
Hampton Jitney
xxxx MCI F3500: 88
North Fork Express/Hampton Express, Inc
1988 MCI 102A2: 13
195x GMC PD 4104 : 125 (Ex Mayflower Coach Corporation #???)
xxxx MCI-9: 607
19xx -------: 615
Coram Bus Service
xxxx MCI-9 : xxx
xxxx MCI-5C: ????
1979 MCI-9: 511-512
1983 MCI-9: 569,573 (#573 went to Charter Bus Lines of British Columbia #204)
xxxx MCI 96A2: 607
Posted: Wed Oct 30, 2013 10:46 am Post subject: |
As of 10/31/13
Alert Coach
19xx MCI MC-9: 3123-3124
19xx MCI: 3129-3130
Hampton Jitney Bus
19xx Eagle Model 15 or 20: 30
1993 Prevost H3-40: 47
1994 Prevost H3-40: 50
2006 Prevost Le Mirage XL II: 106 (Ex Sunrise Coach)
xxxx MCI F3500: 88
2004 Prevost H3-45: 343 (Went to Hampton Jitney # 104, Has Gold and Blue Lettering)
1988 MCI 102A2: 13
19xx MCI: 3,471,2001
19xx MCI 102-DL3: 9804
xxxx MCI D4500: 8
20xx MCI J4500: 2601-2602
Classic Coach
1999 MCI 102EL3: 2001
xxxx Provost Le Mirage XL-II: 2120
xxxx Provost: 2506-2508,2701-2704,2708,2711,2802
Hampton Luxury Liner (2009-Present owned by Classic Coach)
xxxx Provost: 2011,2706,2709,2711-2712 (#2706,2709 was branded for BoltBus, #2711 branded for 7Bus, #2709,2711 ex Classic Coach #2709,2711???)
2011 Provost X3-45: 2801,2803-2804 (#2803 was branded for BoltBus, #2803-2804 branded for 7Bus)
Coram Bus Service
1947 Flxible Clipper: 103
19xx -------: 615
1954 Flxible VisiCoach: ????
1974 GMC P8M-4905A: 504-505 (#504 leased to NJ Transit #6920)
1976 GMC P8M-4905A: 506-507 (#507 leased to NJ Transit #6921)
1977 GMC P8M-4905A: 508,510 (#510 leased to NJ Transit #6922
1979 MCI-9: 511-512 (Leased to NJ Transit #6909-6910)
1979 GMC H8H-649: 514 (leased to NJ Transit #6923)
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, Leased to NJ Transit #6901-6908. 515 went to Private Transportation)
1983 MCI-9: 569
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815,819 (#819 Ex-Worldwide #745, Current Go Buses #9148, #815 Had Portrait of Twin Towers, Went to Horizon Bus Service)
